pic: Part of our 4D navigation system
Re: pic: Part of our 4D navigation system
4d . . I can see how you might be able to track objects over time . . but I'm trying to figure out how you'll change your robots 4th dimensional velocity from 1 second per second to any thing else . . well with using COTS parts.
Yes!!!!
I suggested this a couple of days to our team. Now, there's visual proof it can be done!!!But I was wondering, what's the range of the NXT ultrasound sensor? |
Theoretically, anywhere from 0 to 100 inches. Practically, it's "accurate" (depending on your definition of accuracy) from between about 2 to 40ish inches.
I dont think he meant 4D as you guys are thinking it. The clue was Part of our 4d navigation system. As in the system has many parts, specifically 4 parts. This is one dimension of a four dimension sensor system. (gyroscope, accelorometer, sonar, gear tooth)
Wait...
How are the robot and NXT connected? |
I think they might win an innovation award if they manage to essentially time travel . a devise that runs off a 12 volt battery, and weights less that 100 pounds, and is controller by 2 small processors, impressive to say the least. Also, since its 4-D it will fly. (Note: yes i know that acceleration disrupts the flow of space-time, but the original post inferred true navigation of 4 dimensions not minute undetectable changes)
| Inertial Navigation System - Has it Been Done? | DragonRagnarok | Programming | 8 | 24-01-2008 04:00 |
| pic: A closup view of our prototype worm-crab drive system. | AndyB | Extra Discussion | 6 | 20-01-2008 00:02 |
| Name our Battle bot part 2 | Greg Needel | Chit-Chat | 14 | 23-09-2005 18:08 |
| Name / logoize our Robot Part 3 | Alex Cormier | Chit-Chat | 12 | 03-06-2005 23:51 |
| Inertial Navigation System | CyberWolf_22 | Electrical | 19 | 04-12-2003 17:27 |
