Re: Adapting robot to meet <R16> (was: WE NEED HELP)
If you can spare the weight, consider using pneumatics to shorten and lengthen your arm to fit size requirements.
lean the mast back afew degrees (trig will help you figure out the optimal lean)
and shorten it up abit. |
| need help assembling parts in inventor .. (was: help) | jhallel | Inventor | 5 | 22-02-2007 01:46 |
| what is the green light on the cam? (was: I NEED YOUR HELP!) | RDD | Programming | 3 | 02-02-2007 08:01 |
| how many cold cathodes? (was: NEED HELP) | RDD | Programming | 1 | 01-02-2007 18:28 |
| 2 keyang motor to one spike? (was: need help..!!) | itay_ms | Technical Discussion | 2 | 17-01-2007 13:07 |
| help: cannot get the picture in the labVIEW program .. (was: need help!! quickly!) | liad | LabView and Data Acquisition | 8 | 18-01-2006 12:20 |
