pneumatics help!!!!!!!
When a pneumatics actuator is extended, do we need to use a two-way valve to retract it, or can we use a one-way?
Re: pneumatics help!!!!!!!
The one way valve will work to retract it. The two way valve will stay in the position it was left in after you remove power, but the one way valve will switch back to it's "default" position.
| Pneumatics Help | Zultraranger | Pneumatics | 9 | 26-01-2008 15:05 |
| Pneumatics Help | Transformers | Technical Discussion | 8 | 11-01-2007 19:56 |
| Pneumatics help! | Bomberofdoom | Kit & Additional Hardware | 2 | 08-01-2007 11:32 |
| Pneumatics Help! | archiver | 2001 | 2 | 24-06-2002 00:45 |
| PNEUMATICS PLEASE HELP | archiver | 2000 | 1 | 23-06-2002 23:06 |
