Go to Post FIRST isn't only about winning, it is about making friends, gracious professionalism, and having fun. - lallamavolador [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 05-02-2008, 16:56
Evert Evert is offline
FRC #2185
Evert is an unknown quantity at this point
Toughbox broken
During testing today, the pins in the toughbox that hold the gear broke
I was wondering if anyone else has had this problem?
Unread 05-02-2008, 17:16
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Re: Toughbox broken
Are you talking about the roll pin, the part that you hammered into the shaft? A lot of people have had a lot of difficulty getting these inserted, and it's quite possible that you cracked the pin while inserting it, leading to the failure. We went through a whole handful of roll pins before getting it right, so don't feel too bad.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 05-02-2008, 17:32
GrammarNazi GrammarNazi is offline
FRC #2952
GrammarNazi is on a distinguished road
Send a message via AIM to GrammarNazi
Re: Toughbox broken
Just a hint if you get new roll pins, we found a drill bit the same size as the hole and just wiggled it around in there a little and the went in fine. still extremely tight but the didnt bend.
First one to reply gets a cookie!!!
Unread 05-02-2008, 19:32
Chipawa's Avatar
Chipawa Chipawa is offline
AKA: Mr. Tucker, AKA Chip
FRC #1111 (Powerhawks)
Chipawa is an unknown quantity at this point
Re: Toughbox broken
We drilled our shaft with a 3/32" bit. Hammering the roll pin went much better. Not sure that Andymark would recommend this approach. But so far the gearboxes are working fine.
2010 DC Engineering Innovation Award
2010 DC Spirit Award
2008 Chesapeake Finalist
2008 Chesapeake Rockwell Automation Innovation in Controls award
Unread 05-02-2008, 21:58
Sean Schuff's Avatar
Sean Schuff Sean Schuff is offline
Year 18 in FRC!
FRC #0093 (N.E.W. Apple Corps)
Team Role: Teacher
Rookie Year: 2000
Sean Schuff has a reputation beyond reputeSean Schuff has a reputation beyond reputeSean Schuff has a reputation beyond reputeSean Schuff has a reputation beyond reputeSean Schuff has a reputation beyond reputeSean Schuff has a reputation beyond reputeSean Schuff has a reputation beyond reputeSean Schuff has a reputation beyond reputeSean Schuff has a reputation beyond reputeSean Schuff has a reputation beyond reputeSean Schuff has a reputation beyond repute
Re: Toughbox broken
Might I suggest an arbor press in lieu of a hammer. Or contact AndyMark directly and get a recommendation from them.
Sean
Every child. Every program. Everywhere.
Thanks Plexus Corp. for two decades of partnership and counting...your company gets it!!
www.nacteam93.com | Tesla Engineering Charter School
Unread 05-02-2008, 23:43
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
Re: Toughbox broken
Well... at least you didn't break the back of your transmission. Our toughbox's lexan back plate didn't do so hot (in stress testing) when used with two FP motors into 64:1 gearboxes as input torques. Instead of seeing if it would crack in real life, we just spent the extra weight and made an aluminum backer plate for it. True, it's heavier, but, shouldn't have to worry about it breaking now.
Has anyone had their lexan plate on their toughbox break?
-q
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
Toughbox Assembly mjgard General Forum 39 16-01-2008 19:27
Toughbox - Sketchup Model Projectt2501 CAD 0 10-01-2008 21:24
AM Toughbox Model(s) available Ed Sparks CAD 2 08-01-2008 11:15
Broken promises or BROKEN ROBOTS! archiver 1999 9 23-06-2002 22:18
