Go to Post Thinking about this game within the confines of previous years will limit you. - Gregor [more]
Unread 02-05-2008, 07:37 PM
bronxbomber92 bronxbomber92 is offline
FRC #1551 (Grapes of Wrath)
Rookie Year: 2007
bronxbomber92 is an unknown quantity at this point
Pointer to pwm
I just wanted to make sure this was safe to do.
Code:
typedef struct
     // stuff
     unsigned char* pwm;
} Motor;
void InitMotor( Motor* motor, unsigned char* pwm, /* more parameters */ )
     // stuff
     motor->pwm = pwm;
then if I want to change the motor speed
Motor myMotor; InitMotor( myMoter, pwm10 );
myMotor.pwm = 127; // set it to nuetral
Is that all right to do? I assume it is, but just want to make sure.
Thanks
Suspicious pointer conversion ebowla Programming 2 01-26-2008 12:13 PM
laser pointer 1574aviad Technical Discussion 9 02-20-2005 08:25 PM
pwm 13-15 wayne 05 Programming 2 10-04-2003 12:08 PM
PWM Antonio Technical Discussion 21 01-06-2003 02:44 PM
Pwm VanWEric Programming 17 11-01-2002 04:07 PM
