xbox controller
Hey,
My team wants to use an xbox controller. I know we have to use the usb chicklet. We have one already, but there is one problem. The chicklet does not allow you to use all of the buttons and the two axis on the controller all at the same time. Is there a way we can use them? I was thinking of splicing the wire for the xbox controller and finding out which wires are used for which button. Then just take a 15 pin connector and solder them onto the proper ports that the oi board will recognize and attach that to a different com port. Will this work? We dont want to ruin a controller over this... thanks! |
Re: xbox controller
http://www.ifirobotics.com/dashboard_viewer.shtml It is a great program that will tell you what buttons are doing what, which axis are controlling what, battery levels, and other helpful things. I highly suggest it. Good luck, Jacob |
Re: xbox controller
You can configure it to a variety of modes using the process explained in the datasheet, located at http://www.ifirobotics.com/docs/usbc...ual-rev1-2.pdf
Re: xbox controller
Re: xbox controller
I understand the different modes, but each mode does not include every button and analog stick there is.
For our drive train we need them all. Is there any way i can use them all? |
Re: xbox controller
A joystick port has four analog inputs and four switch inputs. The Chicklet can repurpose analog inputs to encode four more switches. So far as I can tell, supporting more than two analogs and twelve switches simultaneously is simply not possible. It's a hardware limitation of the OI's joystick ports.
Re: xbox controller
what if we were to take out one of the analog wires and wire them to another com port?
Would it then be possible to use everything on that xbox controller? |
Re: xbox controller
Wire them to what other com port? And what "them" are you talking about? I don't understand the question. If you're talking about gutting the controller and wiring it directly to the OI, it could work, but I think the xbox controler's innards are not very easy to connect to. The analog controllers in particular are a very poor match for what the OI joystick inputs expect. |
Re: xbox controller
Sorry for the sloppy question.
But you still understood correctly. We opened up an xbox controller today and saw how the analog is wired and compared it to the joysticks first provides. It seems like exactly the same thing, but on a smaller scale. I guess we will try to connect them and see if it works. I was wondering if it was possible and i guess it is. We will test the "poor match." Ill put up the results once we are done. Thanks. |
| Xbox Controller? | ScottieDo555 | Technical Discussion | 24 | 29-01-2008 16:24 |
| xbox 360 controller installation | kuelin | Technical Discussion | 17 | 07-01-2008 19:43 |
| Chicklet with MS XBOX 360 controller | 354.FIRST | Control System | 2 | 19-04-2007 16:29 |
| Regular Xbox Controller...HELP! | lostandconfused | Control System | 1 | 13-02-2007 14:29 |
| chicklet USB/xbox 360 controller | spsteam1512 | Control System | 1 | 10-01-2007 23:14 |
