Go to Post Admitted to MIT '14. FIRST is good stuff. - sparrowkc [more]
Unread 05-02-2008, 21:48
nukelear1991 nukelear1991 is offline
AKA: Mike Poff
FRC #0858 (Delphi Demons)
Team Role: Tactician
nukelear1991 is on a distinguished road
Total Pneeumatics Pneub (NEED HELP)!!!!!!!!
So I dont understand the pneumatics at all. I dont get how to hool them up, program or anything. I am the new programmer,electronics, and recently elected the pneumatics guy (with no pneumatics knowledge at all). can someone post pictures of their pneumatics systems,coding examples and the like just so I can get somewhere. Dont bother posting links to the manual because I looked at that and didnt understand.
sorry for the trouble and thanks for the help,
Mike
2009 Lansing District Event Champions
Unread 05-02-2008, 21:58
Miner Miner is offline
AKA: Jacob Miner
FRC #2077 (Laser Robotics)
Team Role: Leadership
Rookie Year: 2007
Miner is on a distinguished road
Re: Total Pneeumatics Pneub (NEED HELP)!!!!!!!!
Wow! That is a real handfull that you've got there. How many people are on your team?, and can anyone help you at all?
I dont have any pics of our pnumatics board right now, but here are some suggestions. I am just the electronics guy, but I have worked on pnumatics too. If you know alot about electronics you should be fine. Just think of the compressor as your positive power supply.
There are tubing holders that you screw into the solenoids (which control the pistons), the pistons (which are the metal tubes that extend), and the accumulators. They look like bottle type things and store all of the compressed air. I really wish I had some pics to show you.
REMEMBER TO USE TEFLON TAPE WHEN SCREWING IN CONNECTIONS. If you dont, there wont be a tight seal and you will loose pressure.
Also remember to put on the automatic pressure release valve (look in the KOP check list to find what it is). This can be set from 0-60 psi and must be attatched before the solenoids.
Have a couple other people from your team help you. It is a really tedious job and is quite time consuming. Have them look at the pnumatics manual too.
Good luck,
Jacob
Do what you like... Like what you do!
Jake, the Life Is Good guy
Unread 05-02-2008, 21:59
DonRotolo's Avatar
Back to humble
FRC #0832
The best place to start is to read the pneumatics manual.
Unread 05-02-2008, 22:00
Joe G.'s Avatar
Joe G. Joe G. is offline
Taking a few years (mostly) off
AKA: Josepher
no team (Formerly 1687, 5400)
Rookie Year: 2007
Joe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond repute
Send a message via AIM to Joe G.
Look in the FRC pneumatics manual
http://www.usfirst.org/uploadedFiles...ics_Manual.pdf
It contains diagrams of all the major parts, and how they fit together. We have our system set up as follows:
Compressor, wired to a spike relay. On one end, brass T-fittings are used to attatch the pressure switch, which is wired to a digital input. It should be set up in code so that the compressor is on when the switch is closed, and off when it is open. On the other end, we usually have more brass fittings, connecting it to a pressure gauge and a relief valve. This allows us to see our pressure, and easily release everything at once. From there, air flows to the air tanks, and then through the regulator. This limits the "working pressure," meaning that it only lets so much pressure through, no matter how much pressure is in the tanks. Depending on your needs, you may need multiple regulators for differant pneumatic circuits. The air then flows from the regulators to the solenoids, which are used to turn the flow on and off to differant cylinders. The solenoids must be wired to spikes, which power them. Air from the solenoids then goes to the piston, which uses flow control valves to limit its speed.
As said above, remember to teflon tape your fittings!
I think that sums up the system. Feel free to post if you have more specific questions.
FIRST is not about doing what you can with what you know. It is about doing what you thought impossible, with what you were inspired to become.
2007-2010: Student, FRC 1687, Highlander Robotics
2012-2014: Technical Mentor, FRC 1687, Highlander Robotics
2015-2016: Lead Mentor, FRC 5400, Team WARP
2016-???: Volunteer and freelance mentor-for-hire
Unread 05-02-2008, 22:45
kmcclary's Avatar
kmcclary kmcclary is offline
Founder 830/1015;Mentor 66/470/1502
FRC #0470 (Alpha Omega Robotics)
Rookie Year: 1994
kmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond repute
Originally Posted by nukelear1991 View Post
So I dont understand the pneumatics at all. I dont get how to hook them up, program or anything. I am the new programmer,electronics, and recently elected the pneumatics guy (with no pneumatics knowledge at all). [...]
The first thing you want to do is pull the 2008 Pneumatics Manual and The Robot PDF, from the DOCS area.
Docs & Updates area:
http://www.usfirst.org/community/frc...nt.aspx?id=452
Within that area, are the two manuals -
2008 Pneumatics Manual:
"The Robot" PDF (as of this writing, Rev E, page 26 - get the latest at "node 452", above)
http://www.usfirst.org/uploadedFiles...Robot-RevF.pdf
The Pneumatics Manual gives you the connections. There are nice pics of an entire system built up there, as well. "The Robot" PDF gives you the general robot build rules. That will specify things like how many storage tanks you're allowed to use (4), and the like.
In addition to the "sample" cylinder, you're also given a "coupon" for up to three free Bimba cylinders. Added to the basic air power plant provided in the Kit of Parts, this allows you to choose whatever cylinders you'd like for your application, by stroke and diameter. (In general, the diameter of the cylinder determines your overall maximum force available and air consumption per operation, whereas the stroke determines the distance you are acting over.)
Once you've determined your needs, go here to order the free cylinders:
http://www.bimba.com/FirstFree.aspx
Remember, you only get three free ones, so BE SURE before you order that you're asking for the right ones! They are NON-RETURNABLE.
NOTE - Bimba BUILDS TO ORDER, THEN ships. This means that their Just In Time system can take SEVERAL DAYS *just* to complete the manufacture of your cylinders. Therefore, even if you request "overnight shipping" and pay for it, it may still take several days before you see your cylinders, so be sure to allow for that!
Also, if you do NOT specify "overnight" and give an account to bill against, your cylinders will be shipped UPS GROUND. That can add up to another week to the delivery! Since we're already in Week 5 of the build, in a worst case scenario this may mean you won't see your cylinders until the build is almost over, so I highly recommend providing a billable shipping account to get them ASAP. (Someone over 18 on the team can easily open a FedEx account, so this isn't normally a problem...)
More "gotcha" notes, if you plan to use more than the three free cylinders:
1) The Coupon cylinders AUTOMATICALLY come with clevis, mounts, and (if you request magnetic cylinders) magnetic sensors If you order a fourth cylinder, you will also need to order those accessories separately, or you'll get ONLY a raw cylinder.
2) Use the Bimba price calculator to figure out the best use of your coupon:
http://12.48.113.100/mrcjava/servlet/BIMBANET.M00600s
(IOW, use the coupon for the most expensive cylinders, THEN buy more with real cash. Be sure to add in all accessory prices, too!)
In addition to the FIRST 2008 Pneumatics Manual, here's a link to the full Bimba catalogs for the Bimba Cylinder line, for more tech information:
http://bimba.com/Catalog/Download/
The "Original Line" catalog has the basic cylinder data.
The "Pneu-Turn Rotary Actuator" catalog has the rotary actuator data.
Here are a few other useful pneumatic links for you:
- Pneumatics FIRST.org (kit training)- http://www.pneumaticsfirst.org/
- Festo Valve Assembly - http://a1989.g.akamai.net/f/1989/710...TValveAssy.pdf
- SMC's FIRST component catalogs and assembly data - http://smcusa.com/sections/first/assembly.asp
- SMC's Training links, for FIRST teams: http://smcusa.com/sections/first/first.asp
Overall though, the Pneumatics Manual and The Robot PDF are the two big sources of data. They should answer most of your basic questions.
IMHO, the air system does have a lot of weight overhead to get started. So, if you're going to use SOME pneumatics, my best advise is to use a LOT of pneumatics.
The other gotcha is that you have limited total amount of pneumatic work available from the air system. (IOW, what air you have stored at the start of the round, plus whatever you can compress in a couple of minutes during the round, determines the ENTIRE amount of energy available.) That means although the pneumatics are nice, be careful to match the application to them. Small amounts of work in remote locations (like at a gripper at the end of an complex arm, gear switching, hitch latches, bin releases, etc.) make for great pneumatics applications.
OTOH, if the application requires a LOT of work, you might wish to consider using kit motors driving winches instead of pneumatics, since the battery can provide more total work energy in the allotted time.
Does this answer your questions? If not, and I can be of more assistance, feel free to ask. Good luck!
- Keith
Chief Engineer, FRC 1502 "Technical Difficulties"
Keith McClary - Organizer/Mentor/Sponsor - Ann Arbor MI area FIRST teams
ACTI - Automation Computer Technologies, Inc. (Sponsoring FIRST teams since 2001!)
MI Robot Club (Trainer) / GO-Tech Maker's Club / RepRap-Michigan) / SEMI CNC Club
"Certifiably Insane": Started FIVE FRC teams & many robot clubs (so far)!
2002: 830 "Rat Pack" | 2003-5;14: 1015;1076 "Pi Hi Samurai" | 2005-6: 1549 "Washtenuts"/"Fire Traxx"
2005-(on): 1502 "Technical Difficulties" | 2006-(on): FIRST Volunteer!
2009-(on): 470 "Alpha Omega" | WAFL | Sponsor & "Floating Engineer" for MI Dist 13 (Washtenaw Cnty)
2011: 3638 "Tigertrons" | 2013-(on): 4395 "ViBots" | 2014-(on) 66 "Grizzlies"
"Home" Teams: 66, 470, 1076, 1502, 4395
Local FIRST alumni at or coming to Ann Arbor (UM/EMU/WCC/Cleary)?
...We Want YOU as a Mentor! Please email me for info!
Support CDF Reputation - If a posting helped, thank 'em with rep points!
"It must be FRC build season when your spouse and children become 'Action Items 8 & 9'..."
Total N00B asking for help! kyuketshki Programming 1 10-01-2008 19:02
need help assembling parts in inventor .. (was: help) jhallel Inventor 5 22-02-2007 01:46
hey need some help with writing a code please help me here magical hands Programming 9 01-01-2004 21:46
