Go to Post There are no simple solutions, as every solution has its own problems. - M. Lillis [more]
Unread 05-02-2008, 23:11
vansivallab's Avatar
vansivallab vansivallab is offline
FRC #2583 (Westwood Robotics)
vansivallab is an unknown quantity at this point
Closed circuit
is there any way of creating a closed circuit pneumatics?
so what would happen would be that u would flip a switch and it would go up
or is there a substitute for the micro controller that would go on the robot?
Unread 05-02-2008, 23:22
j_johnso j_johnso is offline
FRC #0226
j_johnso is on a distinguished road
Re: Closed circuit
Yes, there is. The RC sends a small signal to the spike which sends a larger +12 volt output to the pneumatic solenoid. If you were to hook the solenoid to +12V directly, or even with a switch in between, it should work fine.
The switch must be able to handle the current (number of Amps) that the solenoid requires. I don't have the specs off hand, so
i don't know what that value is.
This would be against the FIRST rules, so you would not be able to do this for a competition, but it will work to test, or if you are using pneumatics for another purpose.
Unread 05-02-2008, 23:40
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
Re: Closed circuit
The RC? or the Spike? Either way, the only way you could use something else would be as a slave to the RC...and certainly not in place of a Spike.
The only control system you can use is the one in the KOP--RC, OI, Victor 884s, Spikes.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
pic: Shop Closed?!? geeknerd99 Extra Discussion 15 23-10-2007 10:35
MARRS v0.9 Closed BETA themagic8ball Scouting 8 24-03-2006 22:09
Closed Forums? Brm789 CD Forum Support 3 16-05-2004 15:38
Why is my thread closed? Yan Wang Chit-Chat 31 19-11-2002 09:26
