Go to Post Maybe we can start a FIRST team on Mars. - Karibou [more]
Unread 06-02-2008, 10:58
jonboy jonboy is offline
Engineer/Mentor
FRC #0885 (The Green Team)
jonboy is an unknown quantity at this point
SET command duration?
I assume that the SETxxx(n,n) command when invoked in a function and the function returns, that SETxxx maintains the desired state/action after the return and during interrupts etc until the SETxxx is next invoked or a reset occurs. Correct?
... jon
Unread 06-02-2008, 14:00
Kingofl337's Avatar
Kingofl337 Kingofl337 is offline
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Rookie Year: 1998
Kingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond repute
Send a message via Yahoo to Kingofl337
Re: SET command duration?
SetXXX is a command instructing WPILIb to alter a default setting.
SetPWM(1,X) // Change PWM 1 from Default "127" to a X
SetGyroDeadBand(1 , X) // Change the Default Dead for Gyro 1 to X
SetUserDisplay ( X ) ; // Change the Default OI Display from 0 to X
Once a Set command is executed, it normally doesn't need to be resent unless
you need to modify the parameter. If X changes for any reason you need to recall
the set command.
Example:
// This will run a Victor connected to PWM 1 at full speed (255) forever
Autonomous ( ) {
SetPWM( 1, 255 ) ;
// This will run a Victor connected to PWM 1 at full speed (255) for 1 second (1000ms) then stop (127).
Autonomous ( ) {
SetPWM( 1, 255 );
Wait(1000);
SetPWM( 1, 127 );
FIRST Team 501 PowerKnights - Mentor
FIRST Team 40 Checkmate - Mentor Alum
FIRST Team 146 Blue Lightning - Alumni
Unread 06-02-2008, 14:39
Engineer/Mentor
Adam:
TNX for the prompt reply.
... jon
command listfor c??? jfrank Programming 12 22-01-2008 20:16
assembly command tseres Programming 3 18-01-2008 08:13
Make all command pmzq Programming 3 24-01-2006 16:16
Servo command confusion?!?!?!?! [527]phil Programming 9 15-07-2005 20:10
Run command... frightening archiver 2001 1 24-06-2002 03:37
