Go to Post Hopefully LMFAO will cross paths with FRC71. They've been shufflin' since 2002. - Taylor [more]
Unread 06-02-2008, 13:57
PrincessJae's Avatar
PrincessJae PrincessJae is offline
FRC #2543 (Titan-Bot)
Team Role: Electrical
PrincessJae is infamous around these partsPrincessJae is infamous around these partsPrincessJae is infamous around these partsPrincessJae is infamous around these parts
Send a message via AIM to PrincessJae
xbox controller
The xbox controller only substitutes one joystick right? so how could we possiblly program the thumbsticks to act as the motions of our sepeate motors on a y axis?
Unread 06-02-2008, 14:04
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Re: xbox controller
The OI can handle up to four axes and four buttons per port. You can configure the Chicklet so that the right thumbstick registers as the wheel and aux axes... the Chicklet manual explains how.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 06-02-2008, 14:09
Andrew Schreiber Andrew Schreiber is offline
Data Nerd
FRC #0079
Rookie Year: 2000
Andrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond repute
Re: xbox controller
I assume you mean that you want one of the thumbsticks to control each side of your robot.
Short version, the USB Dongle must be set to Mode 1 and have the xbox controller plugged in. The code will look similar to:
Code:
pwm1 = p1_x; //Right Side
pwm2 = p1_y; //Left Side
That is assuming that the dongle is put on port 1 and your drive motors are pwm1 and pwm2.
Take a look at the user guide for the USB Dongle here Page 5 should show you what the code will reference. Look at XBOX/XBOX 360 Mode 1. Or if you need to still use the x axis on the controllers look at Mode 2.
I hope this helps.
Unread 06-02-2008, 14:23
Re: xbox controller
Thank you that certainly makes sense, we still have problems with our robot reading the analogs, so we switched in the joysticks and they didn't work either. hahah funn =] im sure we'll figure out the problem soon.
Unread 06-02-2008, 17:18
Padre_Vez's Avatar
Padre_Vez Padre_Vez is offline
National Inventor Award Winner 2007
AKA: Jonathan
FRC #0103 (Cybersonics)
Rookie Year: 2007
Padre_Vez is on a distinguished road
Re: xbox controller
I love you guys xbox controller awesome.
Beyond the reach of human range
A drop of hell, a touch of strange
xbox controller borabora Technical Discussion 8 06-02-2008 21:52
Xbox Controller? ScottieDo555 Technical Discussion 24 29-01-2008 16:24
xbox 360 controller installation kuelin Technical Discussion 17 07-01-2008 19:43
Regular Xbox Controller...HELP! lostandconfused Control System 1 13-02-2007 14:29
chicklet USB/xbox 360 controller spsteam1512 Control System 1 10-01-2007 23:14
