mounting relief valve
just a question do you have to mount the relief valve on a certain side of the compressor
Re: mounting relief valve
I dont think so.
No, you can mount it any where easily accessible. We mounted ours on the boom last year so we didnt have to reach inside the chasis to get to it.
The two outlets on the compressor are different sizes. The emergency relief valve will only fit in the larger of the two, so I guess the answer is that yes, you do have to mount it on a specific side.
Not unless you put an adapter on the smaller end or pipe it somewhere else.
I always consider your advise and rule quoting to be definative but don't see a clear or even a lawyered stretching of the rules to disallow what was suggested above in <R95> Quote:
-dave . |
Well the GDC reply to the posting makes a very clear statement that I still don't see in <R95>.
Interesting note, if one doesn't use the compressor, the size of the of the port to which you are attaching relief valve to does not matter. |
#10
You can use the compressor, but have it "off board", ie not mounted to the robot. This way you can charge up the tank(s) with air pressure before a match, and not have to carry the compressor's weight on the robot. This only works for limited air use, such as shifting or running a small cylinder to do some infrequent task.
If you do this, you need two relief valves, one directly connected to the off-board compressor, and another on the robot plumbed to the storage tank side of the regulator. (clarification welcome...this is just an example) |
#11
ya doing that is perfect for teams that have 2 speed transmissions and only switch gears once a match , its saves some weight.
I know a few teams that did that in AIM HIGH |
| Norgen Relief Valve | enpurx | Pneumatics | 9 | 07-02-2008 22:32 |
| Calibration of pressure relief valve | d235j | Pneumatics | 3 | 16-01-2008 14:12 |
| where do i place the norgen relief valve? | Reaper40 | Pneumatics | 1 | 25-01-2007 18:25 |
| Where do we get a relief valve? | P1d40n3 | Pneumatics | 4 | 17-01-2007 10:04 |
| Need the number for the Norgren Pressure relief valve | Jack21 | Pneumatics | 0 | 23-01-2004 16:32 |
