Go to Post Well, there goes my strategy of blowing out the opponent and then committing flagrant safety and sportsmanship violations to keep the margin close :D - Jared Russell [more]
Unread 06-02-2008, 21:25
windell747 windell747 is offline
FRC #2477
windell747 will become famous soon enoughwindell747 will become famous soon enough
Too many interrupts?
Hi, I'm in charge of the programming and I was wanting to use interrupts to track the rising edges of the gear tooth sensors. My mentor is concerned that tracking this (max speed of 10ft/sec) will bog the processor down too much. He is proposing to build a byte counter circuit that will keep count will the processor is doing other things and then the count will be read by the processor for an update and reset. Can anyone provide insight to this?
Thanks,
Windell
Please only respond if you are a credible source because I don't want to make myself an idiot to my mentor when I present him with an argument.
Unread 06-02-2008, 21:29
kevin.li.rit's Avatar
kevin.li.rit kevin.li.rit is offline
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
kevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond repute
Send a message via Yahoo to kevin.li.rit
Re: Too many interrupts?
Where are you planning on mounting the gear tooth? And how many edges is it going to see per time?
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 06-02-2008, 21:45
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
See this thread: http://www.chiefdelphi.com/forums/sh...threadid=63416
Unread 06-02-2008, 23:36
SuperBK's Avatar
SuperBK SuperBK is offline
AKA: BrianK
FRC #1225 (Amperage Robotics)
SuperBK is just really niceSuperBK is just really niceSuperBK is just really niceSuperBK is just really nice
Like the thead points out, the number of gear tooth sensor interrupts are not a problem. They are a relatively low number compared to the encoders that people are using. We are getting around 1200 interrupts per second from the gear tooth sensor. The interrupt routine is simple too - just increment a counter and clear the interrupt flag.
Brian
Brian K
Team 1225 Robotics Mentor
Unread 06-02-2008, 23:55
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
if you still decide you need a divider circuit, you can buy some kits for a very reasonable price
http://banebots.com/pc/ELECTRONICS/EN-A0001-KT
How many interrupts is too many interrupts? Madison Programming 14 08-02-2008 12:09
Too many R/C commands in a loop? ManicMechanic VEX 1 02-07-2007 00:52
pic: TOO MANY TETRAS!!!! Ali Ahmed Extra Discussion 12 22-01-2005 10:06
