Go to Post At this point I think I've absorbed more aluminum into my blood than the iron that was already there. - hectorcastillo [more]
Unread 07-02-2008, 13:18
ggoldman's Avatar
ggoldman ggoldman is offline
FRC #0401
ggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud of
Send a message via AIM to ggoldman
Shooters vs Arms
I wanted to start a discussion on the effectiveness of shooters vs arm lifters.
Here are some pros and cons I see of both:
Shooters
Pros:
Quick release
Can hurdle "on the run"
Cons:
Cannot Place on Overpass at end
Can be "Blocked" easily
Cannot (on their own) knock down balls off overpass
Arm lifters
Pros:
Can knock balls off overpass
Can place on overpass at end of game
Cannot be "Blocked" while hurdling
Cons:
Slightly slower than shooters
Possible High Center of Gravity
In my analysis, an arm lifter can outscore a shooter bot fairly easily:
If an arm bot knocks a ball off the overpass during autonomous and places a ball on the overpass at the end:
20 pt difference
That means that a shooter bot would have to hurdle 2 extra times (and pass finish line) to make up the point difference.
So the question to ask is: Can a shooter get two (or more) extra laps while hurdling when compared to an arm bot?
Please comment and continue this discussion.
Gabriel Goldman
PhD Candidate
RoMeLa: Robotics and Mechanisms Laboratory
http://www.me.vt.edu/romela
Virginia Tech
Horizontal Shooters Sachiel7 Technical Discussion 10 24-02-2006 08:12
2 Shooters??? Jon Jack Robot Showcase 14 26-01-2006 20:00
Shooters or Nonshooters Kevin_547 Rules/Strategy 6 21-01-2006 22:28
Female Shooters JulieB Championship Event 29 28-04-2004 16:47
Pure Shooters Andrew Rudolph General Forum 5 04-03-2002 20:53
