More Buttons
Our current OI includes 3 joysticks. We have a need to use Port 4 to wire in some toggles switches that are not on the current joysticks. I can obviously figure out how to wire up to 4 switches with the base port. Our design requires almost double that. What is the best way to wire a big switch panel to a joystick port.
The only thought I came up with was running each switch through a different value resistor and using an axis. My problem I run in to is sensing multiple switches at a time. Any help would be greatly appreciated. Kyle |
Re: More Buttons
If you don't need more than eight buttons, and you need to be able to detect each of them independently from the others, recall that you have four analog ("axis") inputs in addition to the four switch inputs. Your idea for using resistors is fine; you just need to connect each button/resistor to its own joystick connector pin.
There is also the option of using the redundant switch connections available on two of the joystick ports. You can "steal" switch inputs from one joystick and use them via a different port. See the OI documentation for details on which ports support this. By the way, congratulations on a very good question! You've stated the problem well, and your comments show that you've thought about the solution and you understand the issues. |
Re: More Buttons
Eight digital inputs are available on port 4.
Four of them are also on port 1, but you can disable them on port 1 with the disable switch. If you need even more digital inputs, use port 2 and port 4, and then attach two joysticks to port 1 or port 2 using a Y cable. Eugene |
Re: More Buttons
im working on the operator interface and i was wondering about how many LEDs can be ran off of each imput or if there are any rules about Leds that im not aware of
Re: More Buttons
One button per axis should work. I was over thinking the problem.
Just out of curiosity, is there an easy way to assign four buttons in place of an analog axis and have them accessable via four digital values in the top four bits of the analog channel like the USB-CHICKLET does? Kyle |
Re: More Buttons
I don't know if there is any rule from first but the OI user guide specifically says not to power LEDs off of the joystick ports because current and voltage draw will throw off joystick readings.
"Do not use +5V Aux for lamps or LEDs, excess current will affect joystick readings. The current limit of the +5V Aux from all 4 ports is about 100mA. The Aux Fault Led will start illumination when the current draw from the +5V Aux Outputs total about 120 mA and the +5V Aux voltage will have dropped to about 4.5 volts. Worse case, short condition: after about 30 seconds, the voltage will be at about 300 mV with a current of about 250 mA." It actually says that once for each joystick port. kyle |
Re: More Buttons
just dont draw too much current
Re: More Buttons
the only things ive been able to find is what you guys said so i guess i just have to see how many i can put on without pulling to much current
Re: More Buttons
In theory, the resistor values should be 1/2, 1/4, 1/8, 1/16, and 1/32 of 100k. In practice, some tweaking of values might be necessary. The switches go across the large four resistors. The small fifth one serves to offset the final value so small variations in resistance do not cause the high bits to change. |
#10
Re: More Buttons
My team uses 6 position rotary switches to set our autonomous modes using 2 analog axis. Basically, you solder resistors across the pins and turn the switches to connect the signal wire to different pins. I can get you a part number if you are interested.
#11
Re: More Buttons
Don't they sell pots with detents in them? If they do, I think they would be perfect. Though I couldn't tell you who makes them as I've never used them.
#12
Re: More Buttons
That said you can create a Y cable so that on one joystick your x axis is p3_x and your y axis is p3_y and your trigger and top are p3_sw_trig and p3_sw_top respectively. At the same time, on the same port, the x axis for your second joystick would be p3_wheel and your y axis would be p3_aux and your trigger and top would be p3_sw_aux1 and p3_sw_aux2 respectively. Pavan. Last edited by Pavan Dave : 08-02-2008 at 18:04. |
#13
Re: More Buttons
| Has Being In FIRST Made You More Brave - More Confident? | JaneYoung | General Forum | 25 | 08-05-2007 10:11 |
| more buttons | joesmomh00haha | Programming | 9 | 17-02-2007 10:38 |
| Buttons, Buttons and more Buttons (2006) | Freddy Schurr | Team Organization | 11 | 14-12-2005 21:36 |
| UI Buttons | stephenthe1 | Programming | 4 | 21-03-2005 12:58 |
| Buttons | Rob Ribaudo | Chit-Chat | 11 | 06-04-2002 17:18 |
