Go to Post Same as regrets in life: Learn from them. This is called "growth". - DonRotolo [more]
Unread 07-02-2008, 17:02
Spartan151's Avatar
Spartan151 Spartan151 is offline
TCU Bound (Class of 2013)
AKA: Sean
FRC #2920
Rookie Year: 2007
Spartan151 will become famous soon enough
Burning Spikes
Let me ask a question: what would cause our compressor to blow 3 of our Spike fuses in less than an hour? Would the compressor being to hot have any effect? What causes this? This problem just started today, by the way. What could cause the fuses to blow out?
MORE DUCT TAPE!
Unread 07-02-2008, 17:06
kevin.li.rit's Avatar
kevin.li.rit kevin.li.rit is offline
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
kevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond repute
Send a message via Yahoo to kevin.li.rit
Re: Burning Spikes
I've heard It has something to with the back pressure coming from the tanks causing some sort of current spike. That's why they allow you to replace the fuse on the compressor spike with a auto resetting one. I've only seen it blow once.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 07-02-2008, 17:11
Matt C's Avatar
Matt C Matt C is offline
FRC #1468 (J-Birds)
Rookie Year: 1999
Matt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond repute
Send a message via AIM to Matt C
Re: Burning Spikes
Replace your fuse with a 20A breaker, the initial current draw of the compressor tends to pop the fuses.
Unread 07-02-2008, 19:12
Spartan151's Avatar
AKA: Sean
FRC #2920
Rookie Year: 2007
Re: Burning Spikes
It worked. Thanks guys.
MORE DUCT TAPE!
Unread 08-02-2008, 08:13
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Re: Burning Spikes
Compressor start current is 25 amps and the run current is a little over 10 amps. The compressor is guaranteed to blow the 20 fuse. That is why the 20 amp circuit breaker is recommended
<R67> ...
 The fuse on the Spike relay for the air compressor may be replaced with a 20 Amp Snap-Action circuit breaker..
Al
WB9UVJ
www.wildstang.org
________________________
Burning Man phrontist Chit-Chat 1 23-08-2005 12:56
70 dollars burning up mechanicalbrain Electrical 11 25-05-2005 18:40
FP burning out Max Lobovsky Motors 6 24-02-2004 07:52
Burning IR sensors LittleProton Electrical 5 06-02-2004 09:02
Burning rumors archiver 1999 5 23-06-2002 21:58
