The Bumpers
Does anyone knows a quick and easy way to bumpers on
Re: The Bumpers
Bolt and wing nut, maybe?
Re: The Bumpers
If you intend to follow the rules, then there is only one way, bolts. Please read the rules for bumped design specifications. <R08> "...STANDARD BUMPERS must be constructed as described below.... STANDARD BUMPERS must be attached to the ROBOT with a boltand- fastener system to form a rigid, robust connection to the ROBOT structure..." |
Re: The Bumpers
We used bolts with lock nuts so they won't come off during competition.
Re: The Bumpers
I would use bolts, assuming your pit will have a wrench. Good luck ![]() |
Re: The Bumpers
What if they are magic bolts?
Re: The Bumpers
Uhm, didn't the post state that they're using bolts? With lock nuts. Or maybe I'm missing something here...
| Quick question about the bumpers | iPilipino | General Forum | 3 | 23-01-2008 18:05 |
| can we use the cloth for bumpers? | strawberymochi | Technical Discussion | 2 | 01-02-2007 22:19 |
| Question about the bumpers. | Brad Voracek | Technical Discussion | 16 | 16-01-2007 07:28 |
| Bumpers & the Ramp | Gary Bonner | Rules/Strategy | 2 | 26-01-2006 11:13 |
| Enough with the bumpers! | archiver | 2000 | 2 | 23-06-2002 22:32 |
