Go to Post The scent of a smoking Globe motor is familiar to many. - Alan Anderson [more]
Unread 07-02-2008, 17:50
Torboticsmember's Avatar
Torboticsmember Torboticsmember is offline
AKA: Alan Bartow
FRC #2080 (Torbotics)
Team Role: Driver
Rookie Year: 2007
Torboticsmember is a name known to allTorboticsmember is a name known to allTorboticsmember is a name known to allTorboticsmember is a name known to allTorboticsmember is a name known to allTorboticsmember is a name known to all
Large Fan
Our team was wondering if you could hook up a large fan to the victors like the smaller fans are.
Also I'm pretty sure of this but can you put two motors on one Victor. I am pretty sure you can't I am just making sure
Unread 07-02-2008, 17:51
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
Re: Large Fan
You are correct.
<R56> Each power regulating device (Victor speed controller or Spike relay) shall control one and only one electrical load (motor, actuator or compressor). Multiple low-load devices (e.g. pneumatic valves) may be connected to relay modules (but only one motor may be connected to each relay module).
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 07-02-2008, 17:52
Chuck Glick Chuck Glick is offline
Gone Fishin'
Chuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond repute
Send a message via AIM to Chuck Glick
Re: Large Fan
1 motor = 1 victor. So you are correct. As for the fan, I do know teams have ran without the small ones, as for hooking the big one to the victor, I've never heard of that.
Unread 07-02-2008, 18:13
GaryVoshol's Avatar
Cogito ergo arbitro
Rookie Year: 2000
Re: Large Fan
Note that if you hook up another fan of some sort, it has to run off a KoP motor, which has to be connected through a Victor or Spike.
(since 2004)
Unread 07-02-2008, 18:17
EricH's Avatar
New year, new team
FRC #1197 (Torbots)
Re: Large Fan
If he's talking about the large muffin fans in the KOP, those have KOP motors...
Past teams:
Unread 07-02-2008, 21:19
k4r3n2's Avatar
k4r3n2 k4r3n2 is offline
AKA: Karen
FRC #1525 (Warbots)
Rookie Year: 2007
k4r3n2 is an unknown quantity at this point
Re: Large Fan
How do you hook up the large fans? The entire electronics team is new this year and we're a bit mystified...
Unread 07-02-2008, 21:56
Jim E Jim E is offline
FRC #1523 (M.A.R.S.)
Jim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond repute
Re: Large Fan
Simply hooked it to the fuse panel with a small amperage breaker.
BTW, you won't need a large fan on a victor as long as you allow for adequate airflow into and around it.
They are better suited for blowing on motors that tend to get hot. Many of the FIRST KOP motors have internal thermal protection. A fan and/or makeshift heatsink will help remedy the situation of thermal shutdown when you least expect it..
Team MARS = 1.523 AU from the SUN!
Jim E.
Unread 08-02-2008, 08:08
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Re: Large Fan
Many teams that build their electronics into a box use the large KOP fan to cool the box, while leaving the little fans in place on top of the Victors. There is no FIRST rule for the little fans on the Victors, however, the IFI manual for the Victor 884 specifies the fans need to be kept on the 884. FIRST recommends you follow the IFI manual.
In all of the motors supplied in the KOP, heat is generated in the armature of the motor when overloaded. (Power=current^2 x resistance) The armature only connects to the case through the end bearings and the brush assy, so cooling the case of the motor does very little to reduce the internal heat built up during a match. The FP and the Banebot motors have internal fans and cooling slots that may be helped with cooling air. However, there is no substitute to running the motor in an area of the power curve where efficiency is high and current is low. Please see the Tips and Guidelines for a discussion on motor speed choice.
Al
WB9UVJ
www.wildstang.org
________________________
light up fan Dremel Drew Electrical 9 08-02-2007 23:28
COOL Fan!!! Murf the Smurf Electrical 4 07-02-2006 20:54
Large Papst Fan Sensor Team1726Nerds Electrical 4 16-01-2006 22:48
Sensor use on Papst Large Fan archiver 2001 6 23-06-2002 23:14
Noisey Fan Kyle Fenton Technical Discussion 5 04-08-2001 09:52
