Go to Post That's just the thing about plastic or brass gears; they tend to morph into plastic or brass washers real fast. - Nick Seidl [more]
Unread 07-02-2008, 19:15
synth3tk's Avatar
synth3tk synth3tk is offline
Volunteer / The Blue Alliance
AKA: David Thomas
Rookie Year: 2007
synth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond repute
Team 964's Robit Thingamabob
Here's our robot, codenamed Applesauce, Applesauce, Applesauce. The grabber-type thing is only prototype, but most of it is being made with PVC and aluminum. Yes, it was thoroughly and rigorously tested to make sure that it withstands the wear-and-tear of the game. The electronics board you may see is not the final design.
http://www.bedfordrobotics.org/photos/IMG_1925.JPG
http://www.bedfordrobotics.org/photos/IMG_2084.JPG
http://www.bedfordrobotics.org/photos/IMG_2112.JPG
http://www.bedfordrobotics.org/photos/IMG_2183.JPG
Comments and questions are welcome.
Videos to follow as soon as I pull it off of both the camcorders.
The difference between theory and application is that in theory, theory and application are the same; In application, they are not.
Unread 07-02-2008, 19:28
Jaybee1405
Posts: n/a
Re: Team 964's Robit Thingamabob
Looks good. How tightly are you able to turn?
Unread 07-02-2008, 20:34
synth3tk's Avatar
AKA: David Thomas
Rookie Year: 2007
Heheheheheheheheehe!!! HAHAHAHAHA!!!!! Silly student, tight turning is not important!!! Hehe!! Hardy har har. Haha. whoo. Turning. That's tight.
The proper response to your question is 'No'. Until we beat the programmers into setting up the foot pedal with sensitivity. Haven't gotten around to testing out on a partial field setup, but it does have the capability to turn pretty good.
Unread 07-02-2008, 20:37
Jaybee1405
Posts: n/a
I lol-ed
foot pedal? I believe that's against the rules (if you're serious). The rules allow the Operator Interface controls to include 3 things:
Things on the table
Things worn by drivers
Things held by drivers
Unread 07-02-2008, 20:51
DarkFlame145 DarkFlame145 is offline
That guy
AKA: Dennis
no team (None this season)
DarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud of
Send a message via AIM to DarkFlame145
Before they made size rules about OIs, 145 made an OI from the back seat of a van. You could sit there and the joysticks where mounted to the arm rests The next year there where size rules =P.
TR-X 145 of Norwich, NY: Student 2005-2008
Exploding Bacon 1902 of Winter Park, FL: Mentor 2009
US Navy Corpsman 2011-????
Unread 07-02-2008, 21:03
synth3tk's Avatar
AKA: David Thomas
Rookie Year: 2007
I lol-ed
Things on the table
research. http://forums.usfirst.org/showthread...ighlight=pedal
We don't play when it comes to making sure it's legal this year. Looked it up during week 2. Nice custom assembly, some wood, a sensor or whatever it's called from one of the old joysticks. It works right now, but only in an all-on/all-off sort of way right now. Custom steering wheel to match, it'll be cool.
Unread 08-02-2008, 07:51
synth3tk's Avatar
AKA: David Thomas
Rookie Year: 2007
Ok, video is finally uploaded. http://youtube.com/watch?v=fcNEeOaIcVs
Unread 09-02-2008, 18:03
Shivang1923 Shivang1923 is offline
I make robot go VROOM VROOM!
FRC #1923 (MidKnight Inventors)
Shivang1923 has a spectacular aura aboutShivang1923 has a spectacular aura about
Maybe it was a bad idea using turning wheels (left to right). Tank drive is so much easier to do. You guys kept hitting the wall, so I'm pretty sure that unless you guys get the hang of it soon, you should switch to tank drive.
Unread 09-02-2008, 19:39
Daniel_LaFleur's Avatar
Daniel_LaFleur Daniel_LaFleur is offline
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Daniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond repute
Send a message via MSN to Daniel_LaFleur
Rear wheel steering is difficult, and many times not very intuitive. It also looks like your fixed wheels have more traction than your turning wheels. Good luck working out the 'issues'.
___________________
"We are not now that strength which in old days moved earth and heaven; that which we are, we are;
One equal temper of heroic hearts, Made weak by time and fate, but strong in will
To strive, to seek, to find, and not to yield. "
- Tennyson, Ulysses
Unread 09-02-2008, 21:52
Greg Peshek Greg Peshek is offline
FLL #2054
Rookie Year: 2011
Greg Peshek is a name known to allGreg Peshek is a name known to allGreg Peshek is a name known to allGreg Peshek is a name known to allGreg Peshek is a name known to allGreg Peshek is a name known to all
Any particular reason you have to do rear-wheel steering? (At least that's what I'm guessing you're trying) And why you can't make the turning wheels the front? That's what we're doing with our Ackermann steering setup. Of course you'll still have the problem of not turning quite as tight as you'd like because it's not true Ackermann steering, but it should help.
If you have the programming capabilities I would suggest putting a potentiometer on the rack to sense position. If you have really have the programming capabilities it would be a lot easier for your drivers if the wheels would center themselves when you bring the joystick back to center, instead of having the wheels move when the joystick moves from side to side (essentially making your globe motor a large servo). We had the same problem as you, it being hard to control, but we are remedying it with the situation I just described.
Hope you get it working well.
-Greg P.
Unread 09-02-2008, 22:40
SgtMillhouse648's Avatar
SgtMillhouse648 SgtMillhouse648 is offline
AKA: Malhon Godwin
FRC #0648 (QC Elite)
SgtMillhouse648 has a spectacular aura aboutSgtMillhouse648 has a spectacular aura about
Send a message via MSN to SgtMillhouse648
Haven't been able to watch the vid (dialup), but as for rear wheel steer, 648 did a 3 wheel tricycle drive for 3 years and it worked very nicely. The two front drive wheels were powered by the FP's, and the 3rd was built on a crab module kindof approach driven by a CIM and turned with one of the window motors. It could turn a full +-90, and the programmers programmed in an electronic differential to keep the wheels from slipping. As for driving it, we used a homeade steering wheel made out of one of the wheelchair wheels on a pot. Where the steering wheel pointed, the independent wheel rotated, and a joystick was used for purely throttle. It was an awesome setup, but we ended up ditching it for crab steer last year, and this year, I think we perfected it.....
Malhon
Midwest Regional-
Regional Finalists with 1000 and 447
Rockwell Automation Inspiration in Control Award
Regional Woodie Flowers - Ed Wegscheid
Unread 10-02-2008, 00:36
synth3tk's Avatar
AKA: David Thomas
Rookie Year: 2007
Ok, for those commenting about the turning and rear-wheel drive, thanks. Just a side note, that video is from the beginning of week three, so we've changed a lot since then. We'd already planned on adding potentiometers, which we did. Also a better steering wheel and pedals than the homemade set, but not because it didn't work. Just a bit easier on the hardware side.
Before the setup was this far, I had already grown accustomed to rear steering with an uncalibrated joystick. Originally the plan was to use it the other way around, but for some reason everybody found it easier to drive it this way. Still some testing needs to be done this week, but I think it's set now.
Unread 10-02-2008, 21:46
Jaybee1405
Posts: n/a
I stand corrected.
Unread 10-02-2008, 21:54
Laaba 80 Laaba 80 is offline
AKA: Joey
FRC #1714 (MORE Robotics)
Laaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond repute
From looking at the pictures, your trackball seems underinflated. You may want to add some more air.
Joey
Driving Record - 75-43-8
Coaching Record - 92-65
  #15   Spotlight this post!
Unread 10-02-2008, 21:55
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
I can't see any type of encoding/feetback device on your pinion motor for the steering. Is there any? If not, how are you planning on controlling your steering? (especially during autonomous period)
Our 2007 robot was originally going to rear wheel steer... but we did some physics work and found out that this configuration made the robot inhearantly more easily able to lose control and spin out at high speeds and intensive cornering. Just a warning.
Any photos/videos of your manipulator in action?
Looks good.
-q
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
pic: Team 964's 2008 Group Photo synth3tk Extra Discussion 1 22-01-2008 01:58
pic: 964's programming table synth3tk Extra Discussion 18 14-12-2007 08:39
Thank you Team 179, team 237, team 269, team 303, team 1065, and team 1251 Arefin Bari Thanks and/or Congrats 13 16-03-2006 20:52
Team in a Box V. 2 : Featuring Team 67 and Team 103 OZ_341 General Forum 7 30-01-2006 16:53
