Go to Post What else could you do with a t-shirt? Wait... never mind... I retract my previous statement and realized this is FIRST and we can do anything with anything. ;) - Jeremiah Johnson [more]
Unread 02-08-2008, 12:17 AM
darkdwarven's Avatar
darkdwarven darkdwarven is offline
AKA: Phantom
FRC #2348
darkdwarven is an unknown quantity at this point
Code Error?
When we turn on our switch connected to the copetition port, the program state light on the robot controller turns red and the code error light on the O/I turns on. We may have had a pin short with pin 5 and an adjacent pin, but if there are any other suggestions on how to remedy the problem it would be gladly appreciated.
Thanks for all the help!
Team 2348, Moanalua High School
I have nothing important to say here, thus I've wasted a few seconds of your life. Isn't that depressing?
Unread 02-08-2008, 12:42 AM
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: Code Error?
What is the "switch connected to the copetition port" supposed to do? There are very specific pins that you're permitted to use without voiding your warranty.
If you're talking about putting the controller in autonomous mode, then it's likely that your autonomous routine is doing something to cause the code error. The typical reasons for that to happen are:
  • an infinite loop in the program that keeps the software from getting to the put_data function.
  • a faulty Interrupt Service Routine that fails to clear the source of the interrupt
Error in code light on, trouble finding error Bryan Herbst Programming 16 10-12-2007 09:59 PM
Code error on RC after downloading "bells and whistles" version of Kevins camera code DanDon Programming 6 01-10-2006 06:07 PM
Intermittent Code Error Plloyd Programming 9 04-09-2005 09:37 PM
Error w/ FRC code JamesBrown Programming 2 01-08-2005 04:17 PM
C++ Code Error? Adam Shapiro Programming 9 01-20-2003 01:24 PM
