Go to Post Accidents happen, but they can be prevented with just a LITTLE bit of forethought. - AdamC [more]
Unread 08-02-2008, 12:27
grosh grosh is offline
FRC #2147
grosh is an unknown quantity at this point
How do you control the length a piston will extention/retraction?
Can we control how far the piston on a pneumatic cylinder extends and contracts? We are using the double solenoid with a dual actuated cylinder. When we turn the relay on the piston extends to its FULL length. We tried turning the relay off before the piston was in it's fully extended position, but it didn't stop. Can you control the length the piston extends with programming?
Pneumatics-Code [and piston output length] reilly Programming 5 13-02-2005 11:42
Pneumatics-Code [and piston output length] reilly Technical Discussion 0 10-02-2005 12:21
How to control piston? Goaliexam Control System 2 07-02-2005 17:20
How do you Calculate Belt Length? Gabriel Technical Discussion 7 08-11-2004 14:54
how do i control a piston with a joystick Ryan Foley Programming 2 27-05-2003 17:13
