Go to Post As I told my friend Joe Johnson, just because you aren't around as much doesn't mean that you can just close the book on this chapter, instead - just keep a book marker in this place, so you can remember how to find your way back home - when the time is right. - meaubry [more]
Unread 04-06-2008, 19:29
gblake's Avatar
gblake gblake is offline
6th Gear Developer; Mentor
AKA: Blake Ross
no team (6th Gear)
gblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond repute
Re: How do you control the length a piston will extention/retraction?
Originally Posted by grosh View Post
Can we control how far the piston on a pneumatic cylinder extends and contracts? We are using the double solenoid with a dual actuated cylinder. When we turn the relay on the piston extends to its FULL length. We tried turning the relay off before the piston was in it's fully extended position, but it didn't stop. Can you control the length the piston extends with programming?
If you simply want to shorten its travel so that only goes to a single location - You use something mechanical to stop it when it has gone that far (you put something sturdy enough in front of it... ).
I'll see if I can dig up a URL to an article I recently read in Machine deisn about the math behind doing this with high precision.
Blake
Blake Ross, For emailing me, in the verizon.net domain, I am blake
VRC Team Mentor, FTC volunteer, 5th Gear Developer, Husband, Father, Triangle Fraternity Alumnus (ky 76), U Ky BSEE, Tau Beta Pi, Eta Kappa Nu, Kentucky Colonel
Words/phrases I avoid: basis, mitigate, leveraging, transitioning, impact (instead of affect/effect), facilitate, programmatic, problematic, issue (instead of problem), latency (instead of delay), dependency (instead of prerequisite), connectivity, usage & utilize (instead of use), downed, functionality, functional, power on, descore, alumni (instead of alumnus/alumna), the enterprise, methodology, nomenclature, form factor (instead of size or shape), competency, modality, provided(with), provision(ing), irregardless/irrespective, signage, colorized, pulsating, ideate
Unread 10-10-2008, 22:54
kmcclary's Avatar
kmcclary kmcclary is offline
Founder 830/1015;Mentor 66/470/1502
FRC #0470 (Alpha Omega Robotics)
Rookie Year: 1994
kmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond repute
Again, not with the kit valves UNLESS you use ONE valve to plug the exhaust ports of your cylinder's directional control valve when commanded.
However, there are two things you need to do, to make this work cleanly: Get the correct TYPE of valve, and add feedback sensing.
1) Valve change - If you go to the SMC website, you can order a Center Off version of the same series of SMC dual coil valve we use, and substitute it. In this style, turning coil 1 ON (and coil 2 OFF) moves it one way, and turning coil 2 ON (and coil 1 OFF) moves it the other way. When both coils are OFF, it plugs both ends of the cylinder, and it "stops". Buy the valve itself, and use the 12V coils and the manifold from one of the kit valves.
This however is only half of the problem, as others have mentioned air is compressable. Change the load (or the direction of gravity), and the cylinder rod may move on you because after all, you are only balancing a PAIR of forces against the load (the air charge on either side of the disc inside).
2) Next, "close the loop" by adding feedback to directly (or INDIRECTLY) detect the position of the piston, and DO something about it if it is in the wrong place.
The simplest form with is to add sensing to the thing you are operating. If the cylinder is twisting a joint, add a potentiometer to that joint. It's value is the important thing anyway, and will have some direct functional relationship to the piston's position.
If you order the MAGNETIC version of the Bimba cylinders (which we ALWAYS do!), you can sense key positions with the supplied strap on reed switches. It's also theoretically possible to whip up a sensor on the outside of the cylinder and have the magnet act like a LVDT core, but I've yet to see anyone desparate enough to directly measure the cylinder to implement one. (Again, it's easier to measure the thing you are operating!)
You can also add a String Potentiometer, or a String Encoder alongside the cylinder's back end, and attach the string to the Clevis. This gives you a direct readout of the cylinder's position, but this is the EXPENSIVE way to go, if you try to buy a commercial device vs making one. (Yet again, you're often MUCH better off watching the device the cylinder is operating!)
In all cases, if your sensor shows that the cylinder/device setup has moved too far away from where you want it to be, simply pulse the appropriate valve to move it back. This kind of closed loop control automatically compensates for load variances, such as grabbing or releasing the scoring object for this year's game from a gripper.
Does this help?
- Keith
Keith McClary - Organizer/Mentor/Sponsor - Ann Arbor MI area FIRST teams
ACTI - Automation Computer Technologies, Inc. (Sponsoring FIRST teams since 2001!)
MI Robot Club (Trainer) / GO-Tech Maker's Club / RepRap-Michigan) / SEMI CNC Club
"Certifiably Insane": Started FIVE FRC teams & many robot clubs (so far)!
2002: 830 "Rat Pack" | 2003-5;14: 1015;1076 "Pi Hi Samurai" | 2005-6: 1549 "Washtenuts"/"Fire Traxx"
2005-(on): 1502 "Technical Difficulties" | 2006-(on): FIRST Volunteer!
2009-(on): 470 "Alpha Omega" | WAFL | Sponsor & "Floating Engineer" for MI Dist 13 (Washtenaw Cnty)
2011: 3638 "Tigertrons" | 2013-(on): 4395 "ViBots" | 2014-(on) 66 "Grizzlies"
"Home" Teams: 66, 470, 1076, 1502, 4395
Local FIRST alumni at or coming to Ann Arbor (UM/EMU/WCC/Cleary)?
...We Want YOU as a Mentor! Please email me for info!
Support CDF Reputation - If a posting helped, thank 'em with rep points!
"It must be FRC build season when your spouse and children become 'Action Items 8 & 9'..."
Pneumatics-Code [and piston output length] reilly Programming 5 13-02-2005 11:42
Pneumatics-Code [and piston output length] reilly Technical Discussion 0 10-02-2005 12:21
How to control piston? Goaliexam Control System 2 07-02-2005 17:20
How do you Calculate Belt Length? Gabriel Technical Discussion 7 08-11-2004 14:54
how do i control a piston with a joystick Ryan Foley Programming 2 27-05-2003 17:13
