Go to Post 119.9999999 pounds...if only the programmers could make the code a bit lighter! - James1902 [more]
Unread 08-02-2008, 14:35
Ian G Ian G is offline
BUILD SUCCEEDED
FRC #2415 (WiredCats)
Ian G is an unknown quantity at this point
Send a message via AIM to Ian G
Mplab output window gone
Mplab will not open the output window. It is checked under the view tab, but is no where to be found. I have reinstall, restarted, and even applied the build patch, and it is still gone. I have tried creating a new workspace, no change. I am using Windows Vista, and Mplab v8.0 with C18 v3.15. The problem first started when I tried to use Kevin's 08 sensor code. Thank you for any help you can provide. I apologize if there is already a thread on this topic, I couldn't find it.
-Ian
Unread 08-02-2008, 14:54
mgurgol mgurgol is offline
FRC #1094
mgurgol is just really nicemgurgol is just really nicemgurgol is just really nicemgurgol is just really nicemgurgol is just really nice
Re: Mplab output window gone
I don't know if this will help, but is there a scroll bar on the right side of the IDE. I have been caught by this with some of Kevin's code, he must develop on a large monitor. Expand MPLAB to full size, and see if the Output has been scrolled out of sight.
Unread 08-02-2008, 15:05
tdlrali tdlrali is offline
FRC #0469 (Las Guerrillas)
tdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud of
Uncheck it in the views window, and then check it again. This happens every once in a while.
Unread 08-02-2008, 16:19
BUILD SUCCEEDED
Thank you, I feel like such an idiot...
Unread 09-02-2008, 16:21
3dude_2231's Avatar
3dude_2231 3dude_2231 is offline
no one messes with a Thingy =|
AKA: Menscher,Ran Menscher =]
FRC #2231 (Onyxtronix)
Team Role: Leadership
Rookie Year: 2007
3dude_2231 is a jewel in the rough3dude_2231 is a jewel in the rough3dude_2231 is a jewel in the rough
Send a message via MSN to 3dude_2231
aggrevating problem indeed..
Redefining the word "Rookie". (for 2 years now..)
Israeli Off Season Games: WINNERS!
check out this cool project I'm into..
using the MPLAB IDE MPLAB SIM simulator WizardOfAz Programming 1 03-11-2003 01:24
I will be gone... Jack FIRST Scouting Network 4 20-07-2003 15:55
All Window Stickers Gone! Please stop e-mailing me! archiver 2001 0 24-06-2002 03:48
Window Motor Output Shaft Spur Gear Specs archiver 2000 1 23-06-2002 22:56
Chat is gone... Brandon Martus Announcements 0 14-06-2002 16:39
