Go to Post GP is a much longer-term investment, yet offers surprisingly high returns. Just like 401(k) plans, the important thing is to keep making contributions even when it seems there's no reward for it. - ayeckley [more]
Unread 08-02-2008, 15:38
Bacu Bacu is offline
FRC #2393
Bacu will become famous soon enough
Absolutely lost
if you hadn't guessed, I'm a first year. Somewhat proficient in C, but I can't find the source code for the bot. I've got all the 2008 software (C18 compiler, ITI loader, etc) is the code in there? if so, where? I've looked at all the code that's in the topics pinned, but I didn't see anything that looked relevant? Shouldn't there be some huge .c file?
Unread 08-02-2008, 16:09
Nathan's Avatar
Nathan Nathan is offline
FRC #1501 (Team T.H.R.U.S.T.)
Rookie Year: 2007
Nathan has a spectacular aura aboutNathan has a spectacular aura aboutNathan has a spectacular aura about
Re: Absolutely lost
Go to http://ifirobotics.com/rc.shtml. Scroll down to the bottom of the page and download "2007 RC Code."
You might also want to read this post http://www.chiefdelphi.com/forums/sh...1&postcount=62
Hope that helps,
Nathan
Save money with PriceWombat, a shopping comparison and price tracking tool (that I made!).
Check out my hobby electronics business!
My former robotics team: Huntington County 4-H Robotics
Unread 08-02-2008, 16:15
Alexa Stott's Avatar
Alexa Stott Alexa Stott is offline
All I do is twin.
AKA: elixir
FRC #0025 (Raider Robotix)
Alexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond repute
Send a message via AIM to Alexa Stott
Re: Absolutely lost
Actually, if I recall correctly, the 2007 code will not work with version 3.0+ of the compiler.
To get the correct version, you can go to Kevin Watson's website to download the proper code for this year. There are two versions on there: ifi_frc_sensor and ifi_frc_simple. The differences are explained on the site.
When you try to compile your code, you may get an error about "clib.lib." To fix this, simply go to Project-->Build Options-->Directory. Then go to the Library Search Options and create a new one that points to wherever mcc18\lib is on your computer.
Hope this all helps.
EDIT: You may consider also looking in this thread for more information about this year's code.
|Email:alexastott[at]gmail.com|Facebook|@zelixir|Google+|
[University of Maryland Computer Science, Psychology]
[Brunswick Eruption]
Unread 08-02-2008, 16:33
FRC #2393
Re: Absolutely lost
Okay got the code and saved all those .pdf and I got the code from kevin's site.
a few more questions:
is there any exceedingly complicated procedure to load the code to the bot?
how exactly do you switch from Autonomous mode to Telop?
Unread 08-02-2008, 16:43
All I do is twin.
AKA: elixir
Re: Absolutely lost
To load the code into the bot, simply compile (ctrl+F10), go to IFI Loader and navigate to the folder in which your code is contained. There should be the appropriate *.hex file there. Connect your laptop to the robot using the black serial cable you got in your electronics kit (you may need to use a USB to serial converter depending on your laptop--these are available at Radio Shack). Hit the "PROG" button on your robot controller for about 3 seconds or so and the Program State LED should light up amber. Then download your code to the robot.
As for switching between autonomous/hybrid and teleoperated mode, here are a few threads that address this topic:
http://www.chiefdelphi.com/forums/sh...ad.php?t=63375
http://www.chiefdelphi.com/forums/sh...ad.php?t=62644
LOST!!! kireitenshi00 FIRST Tech Challenge 1 04-11-2005 09:35
lost teams archiver 2000 3 24-06-2002 00:25
