Go to Post If you speak three languages, you're trilingual. If you speak two languages, you're bilingual. And if you speak one language, you're American. - Hieb [more]
Unread 08-02-2008, 19:42
Pneumaticsman's Avatar
Pneumaticsman Pneumaticsman is offline
AKA: Mitch guzman
FRC #1566 (Ammoknights)
Rookie Year: 2007
Pneumaticsman will become famous soon enoughPneumaticsman will become famous soon enough
Send a message via MSN to Pneumaticsman
Ribbon cable
can we use Ribbon Cable from an electronics store, such as Radio Shack?
Thanks
Unread 08-02-2008, 19:43
lukevanoort lukevanoort is offline
in between teams
AKA: Luke Van Oort
lukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond repute
Send a message via AIM to lukevanoort
Re: Ribbon cable
That depends, what do you want to use it for?
Team 1219: 2009 - Mentor
Team 587: 2005 - Animator, 2006-2008 - Team Captain
Unread 08-02-2008, 19:57
AKA: Mitch guzman
Rookie Year: 2007
Re: Ribbon cable
sensors and encoders.
Unread 08-02-2008, 19:59
EricH's Avatar
EricH EricH is online now
New year, new team
FRC #1197 (Torbots)
Re: Ribbon cable
Guess what?
<R71> Ribbon cable smaller than 24 AWG may be used to connect signal lines to the 9-pin ports on the Robot Controller.
That does appear to be the only place you can use it, though.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 08-02-2008, 20:00
in between teams
AKA: Luke Van Oort
Re: Ribbon cable
It has to be 24AWG or larger (unless going into the serial ports as Eric mentioned above); if it meets that requirement, it is legal. BTW, the answer to this question and many others can be found (probably faster too) in the robot section of the manual.
Ribbon Cable emusteve Electrical 6 13-01-2006 16:33
Ribbon cable sources. Rickertsen2 Electrical 9 19-01-2004 16:23
Ribbon Cables for Digital Input Caleb Fulton Electrical 5 06-02-2003 08:39
CABLE BOOTY BURGLAR OCCRA 2 30-09-2001 13:10
