Go to Post FIRST may very well be the healthiest drug on the market. - Herodotus [more]
Unread 08-02-2008, 20:15
antiNeo antiNeo is offline
FRC #1569
antiNeo has a spectacular aura aboutantiNeo has a spectacular aura about
ADC not initializing
I'm using the latest 2008 ifi_frc_sensor code from kevin.org. I'm trying to get ADC initialized so that I can use the gyroscope, but when I try to call Initialize_ADC() inside of the Initialization() function and upload the code to the robot, the robot's Program State light continues blinking as though it's still downloading the code but it has already completed. I tried to do a bit of debugging with the Initialize_ADC() function and I discovered that when I comment out the line that says "T4CONbits.TMR4ON = 1;", line 222, the robot doesn't get stuck blinking the amber Program State light, but obviously I don't get good gyro values.
Thanks in advance for any help,
Jonathan
ADC #pragma cprogrammer Programming 1 26-10-2006 20:42
Problems Initializing Serial Driver... neilsonster Programming 0 13-02-2005 23:27
Initializing autonomous mode Mr. Lim Programming 7 02-02-2004 07:26
Header Not Found (adc.h) NotQuiteFree Programming 2 23-01-2004 16:26
Change to Initializing Inputs and Outputs Jferrante Programming 4 07-01-2003 11:36
