Go to Post ...why do programmers have a nesting habit? - Andrew Schreiber [more]
Unread 08-02-2008, 23:01
KGood's Avatar
KGood KGood is offline
Capt'n
AKA: Kevin
FRC #2134 (Aztec Pirates)
Team Role: Leadership
Rookie Year: 2007
KGood is an unknown quantity at this point
Controller size limit?
Hey, I was wondering if there is a limit to the max. size of the controller, thanks in advance for the replies!
Taco.
Unread 08-02-2008, 23:02
Laaba 80 Laaba 80 is offline
AKA: Joey
FRC #1714 (MORE Robotics)
Laaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond repute
Re: Controller size limit?
You only get a certian space to set your controllers on. I dont know the exact dimensions though. If I find anything I'll let you know.
Joey
Driving Record - 75-43-8
Coaching Record - 92-65
Unread 08-02-2008, 23:11
AKA: Joey
Attached to the Alliance Station Wall are three aluminum shelves to support the robot control
systems of the three teams on the ALLIANCE. The support shelf measures approximately 60
inches wide by 12 inches deep. There is a 4-1/2-foot long by two-inch wide strip of Velcro tape
(“loop” side) along the center of the support shelf that may be used to secure the ROBOT controls
and Operator Interface. Each setup location includes a competition cable that attaches to the
“Competition Port” of the Operator Interface. This cable provides power for the team’s Operator
Interface and controls communications with the ROBOT. Emergency Stop (E-Stop) buttons for each
team are located on the left end of each Player Station shelf. Arena components (including team
number displays, competition arena hardware, alliance lights, control hardware cabinets and clock
displays) are also located above the Player Station and below the shelf.
Here is all the info you need. Let me know if you have other questions.
Joey
Unread 09-02-2008, 13:44
KGood's Avatar
Capt'n
AKA: Kevin
Rookie Year: 2007
Sweet, thanks!
Yeah, does it matter what type of controller it is?
For example, could we use a steering wheel from a PS2? =)
Unread 09-02-2008, 14:10
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
Originally Posted by KGood View Post
Sweet, thanks!
You can use that controller. In fact, any controller is legal, as long as it connects to the ports on the OI. You can put a Chicklet in between if it's a USB connector, or you can make your own connection.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 09-02-2008, 16:27
DonRotolo's Avatar
Back to humble
FRC #0832
Some relevant rules. THIS is why everyone keeps saying to read the manual, because the answers to most questions are in there. EricH is correct that you can make your own connection, but it needs to follow the rules - a PDA cannot be used, for example.
<R101> The OPERATOR CONSOLE designed by the team must fit on the 60” wide by 12” deep shelf in the Alliance Station (excluding any items that are held or worn by the DRIVERS during the MATCH).
<R105> All equipment connected to the joystick ports of the Operator Interface must be powered solely through the power available through the port. External power sources of any type are not permitted on any equipment connected to the joystick ports. Portable computing devices must not be connected to joystick input ports on the Operator Interface. Power-passive
devices (e.g. joysticks that draw their power solely through the Operator Interface joystick port) are permitted.
<R106> Devices connected to the joystick ports of the Operator Interface via a FIRST-approved USB adapter (the only approved USB adapter is IFI Part Number USB-CHICKLET) are excluded from Rule <R105>. If used, this USB adapter must be powered with a 7.2V battery functionally identical to the back-up battery. Power from the competition port or any other
source shall not be used to power the USB adapter. The USB adapter must be positioned within the OPERATOR CONSOLE so that the indicator lights may be seen during inspection and operation in a MATCH.
Using a limit switch to limit motion ManicMechanic Programming 16 20-12-2007 00:54
Wire Size Limit? (InsrtNameHere) Electrical 2 15-02-2006 20:20
[OCCRA]: Size limit of Operator Control Station Alex Golec OCCRA Q&A 1 11-10-2005 05:33
32k controller limit flounder22001 Programming 9 07-02-2005 00:01
Robot Controller File Size Limit ?? RoboGeek Programming 1 17-01-2005 19:59
