Go to Post Win, Lose or Tie, but do it in a way that FIRSTers will be talking about for years to come! - Bill Moore [more]
Unread 10-02-2008, 23:03
vhcook's Avatar
vhcook vhcook is offline
Reader of Things
AKA: Victoria
FRC #1939 (Kuh-nig-its)
vhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond repute
Re: Musings from a FIRST Inspector
Originally Posted by ebarker View Post
Q. The Allen-Bradley gray, black, red distribution blocks - where does the 2 thin grey pieces go ?
One side of the red and black blocks is open. The thin grey pieces go between the open side of each polarity grouping and the grey block that would end up next to it. The little plastic pegs on the corners of the thin grey piece will fit neatly into holes in the face of the red/black block.
Unread 10-02-2008, 23:41
Kims Robot's Avatar Unsung FIRST Hero
Kims Robot Kims Robot is offline
Onto a New Chapter...
AKA: Kim O'Toole Eckhardt
Rookie Year: 1996
Kims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond repute
Send a message via AIM to Kims Robot
Another thing... if the inspection station is open and ready, go and size & weigh your robot IMMEDIATELY after you take it out of the box. Sometimes your scale in the shop may not be the same as theirs, or your CAD modeling missed the placement of the flag holder and you are outside. Even if you are 100% certain you are good, or bad, see how you stack up with the REAL setup.
A little reason why... at RIT last year, we got there, found out our scale or theirs was 5lbs off... we shaved that, and just made it in under by the end of the day... and by end of the day, I mean we literally weighed our robot AS we were being thrown out the door... put it on the cart, and came back first thing the next morning. Friday morning, we all of a sudden were 3lb overweight again!! Luckily we ripped off the camera and a plastic panel and were legal, but it was crazy to see the calibration of the scale change that much over the course of a day!
And I've been an inspector before as well... let it be fun, let the kids use it as a time to really show off how much they have learned! I want to say that at least 75% of the inspectors are there to help you and can point you to other teams that can give you a hand if you need something, or will give suggestions on how to fix things.
Have fun & START EARLY!!!
~kim~
Kimberly O'Toole Eckhardt <3
Principal Systems Engineer & Program Manager
History - Team 176, Team 229, Team 1511, FIRST Volunteer!!
My new FIRST Photography Hobby & Angry Eric's Fan Page
Excellence - is the result of caring more than others think is wise, risking more than others think is safe, dreaming more than others think is practical, and expecting more than others think is possible.
Unread 11-02-2008, 07:53
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Question:
<R16> I take to mean that the robot must remain in the 80" cylinder at all times even though it is possible that a malfunctioning robot could exceed that. For example we have two arms that deploy. It they deployed together then it violates the rule. In proper operation they will deploy in sequence and not violate the rule. Does the inspector inspect for 'worst case' or do they leave that to the field scoring judge ?
Q. The Allen-Bradley gray, black, red distribution blocks - where does the 2 thin grey pieces go ? and are they necessary ? And why do the wires keep coming out of the block so stinking easily ? I don't remember having this problem in the past.
Ed,
The 80" cylinder is question we will all struggle with this season but I would interpret the rule that your failure mode may very well violate the intent. Best asked on the Q&A for clarification.
The thin grey pieces are needed when the block is used for high voltage. The Kit Of Parts Rev A has a drawing on how to assemble the block and they are not included in that drawing. The wires pull out if they are not stripped 5/8". When you insert a correctly stripped wire, the end of the wire should contact the inner plastic wall (wire stop) of the block and you should be able to just see bare copper at the entrance of the terminal. When you tighten the clamp, the wire will be secure. Add appropriate wire management so that the wire does not wiggle around in the block and you should be fine.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 11-02-2008, 08:30
k4r3n2's Avatar
k4r3n2 k4r3n2 is offline
AKA: Karen
FRC #1525 (Warbots)
Rookie Year: 2007
k4r3n2 is an unknown quantity at this point
Thanks for the advice - this is the first year that I'm going to have to go to inspection with our robot and it was really helpful!
In regards to the power distribution block, my team found that either our wires would spread out over time, or our screws would loosen - if you're still having issues with your wires falling out of your block, try tightening them every morning before you run the robot. Also make sure that they are stripped to the proper length and inserted until the manual stop - these should all prevent the wires from falling out again.
Unread 11-02-2008, 10:16
Unsung FIRST Hero
Rookie Year: 1996
By the way...
Weigh and size are free so come in whenever you want to check. I won't start your paperwork until you tell me you are ready.
Al
WB9UVJ
www.wildstang.org
Unread 10-02-2008, 22:47
lukevanoort lukevanoort is offline
in between teams
AKA: Luke Van Oort
lukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond repute
Send a message via AIM to lukevanoort
To give some advice from the team/student's perspective:
1) Relax. Inspections are only stressful if you let them be. Remember, both you and your inspector are trying to enjoy the competition, not stress each other out. Tell an amusing anecdote or two if it helps (just don't start on some bad "a blonde walks into a bar... ouch" type of jokes and stories).
2) The scale is usually open for use for a lot of the day. So, the first thing you should do after uncrating your robot is to go weigh it. It makes for an unpleasant surprise if you discover at 5pm that you are over the weight limit. It doesn't have to be part of an inspection or any sort of official weigh-in, just get an idea of where you stand.
3) Partial inspections are your friend. Since there is only one sizing box, in my experience, a lot of time is wasted waiting to use it. Get weight/sizing done early and the rest should be a breeze. If you know your electronics won't pass at the moment for some reason, go ahead and do the rest while you wait for the parts to fix the electricals. The same goes for just about anything. (Just don't try to get a partial inspection when the incomplete subsystem poses a hazard to the inspector)
4) Know the rules well and keep copies of relevant Q&A responses and the rulebook at hand. Everyone fears getting an incompetent (or just inexperienced, which can have the same result) inspector, and it does happen (usually pretty rarely though). Knowing the rules like the back of your hand is the most effective way to get through such an inspection.
Team 1219: 2009 - Mentor
Team 587: 2005 - Animator, 2006-2008 - Team Captain
Unread 09-02-2008, 12:22
Steve_Alaniz Steve_Alaniz is offline
FRC #2848 (All Sparks)
Rookie Year: 1997
Steve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond repute
Wayne,
This is Excellent. This list should be included in the manual with the Robot Checklist. Or all regionals should have copies given to the teams as Highly Recommended reading. Thanks for putting this together. It's all simple stuff but having the bumper off alone could save a LOT of valuable time, and Frankly, I hadn't thought of that!
Steve
(You can be rented? How much?)
Originally Posted by Wayne Doenges View Post
Now that we are almost done with the bulild season I would like to put forth some information about when you get to your regional(s) and need your robot inspected.
1) Have your BOM (Bill of Material) ready in a hard copy format. There is no guarantee that someone will be able to print one for you from your jump drive.
2) Leave the bumpers off when you get your robot sized. It's a real mess when you have a team removing their bumpers, in the inspection area, and other teams are trying to get their robot inspected. Some regionals don't have allot of room for this (ie BMR)
3) Please have only two students interact with the inspectors. It's alright if the team wants to watch, but please do it from a short distance away. It's hard for an inspector to ask questions, about the robot, and four people answer.
4) Make sure there are NO sharp corners, protruding screws etc on your robot. I don't like to see blood, especially my own
5) Don't wait until the last minute to get your robot inspected.
The inspectors are here to help you enjoy your FIRST experience and we are not out to pick on you.
If any other inspectors would like to add to this list. Feel free to comment.
Thanks
Your BMR Inspector
ps I can't be bought, but I can be rented
Unread 10-02-2008, 08:50
Richard Wallace's Avatar
Richard Wallace Richard Wallace is offline
I live for the details.
FRC #3620 (Average Joes)
Rookie Year: 1996
Wayne, can we rent you to help with inspections in St. Louis?
All of your points are great advice. My favorite robot is the one that breezes through inspection because the team is prepared and everything is tidy.
This year, inspectors will be looking carefully for sharp edges, corners, points, or anything that might pop a trackball (or draw blood ).
Richard Wallace
since 2003
Unread 16-02-2008, 22:23
KarlSTA KarlSTA is offline
FRC #2574
Rookie Year: 2007
KarlSTA is an unknown quantity at this point
We're a first year time and I'm trying to look ahead and smoothen out a bit of the inspection process. I saw the advice you gave and I appreciate it. Could you give me a little more information on the Bill of Material. What all is required on that? We had some parts custom made by a mentor who works at a steel plant. How do we get those parts on there. Plus once we got some of the steel....we ended up "altering" (aka.....chopping off parts) of some of the custom made pieces. Is all that legal as long as we deburr the metal. While at the places....can you talk to an inspector and have them come look at your robot before you go to official "inspection" to make sure they think it will pass so that....if they don't think it will...you can make some changes. Thanks for the help.
Unread 16-02-2008, 22:28
EricH's Avatar
Happy Birthday! EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
You get multiple chances to pass inspection. The inspectors will be more than happy to give you a "partial" if you don't pass the first time around. They also tend to like to inspect in your pit, as it relieves congestion around the weigh station/size box.
On that note, the earlier you start the better.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 18-02-2008, 07:53
Unsung FIRST Hero
Rookie Year: 1996
Karl,
The inspector is there to make sure you play. He is your friend, please come over and ask questions. I will be stopping by all pits during the practice day Thursday. Wave me over if you have an issue. I (most inspectors) would rather you be ready for a complete inspection when you come for inspection, than to go through multiple partial inspections. It is more efficient for you to go through the list and check over everything before I see your robot. That way as I go through the list, you can point out the areas I am interested in and the process will go very quickly. Inspection should take no longer than 15 minutes.
As to the BOM, the robot rules Section 8 has some examples of how to handle BOM entries and costing. Simply read through the section to get an idea of how to handle your parts. It might require some research on your part to get an accurate cost.
Al
WB9UVJ
www.wildstang.org
Unread 19-02-2008, 13:30
Wayne Doenges's Avatar
Wayne Doenges Wayne Doenges is offline
We Build Robots......and Careers
AKA: Warthog
FRC #1501 (Team T.H.R.U.S.T.)
Rookie Year: 2000
Wayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond repute
Al, correct me if I'm wrong. The B.O.M. is mostly the extra parts and pieces you buy/get donated above the KOP parts.
The custom made parts you need to have the mentor estimate what the parts are worth.
If you buy a 10' long piece of steel but only use 2' than divide the 10' piece price by 5 to get the correct BOM price.
You do not need to include any small hardware (screws, bolts etc..) on the BOM.
Don't sweat the small stuff, we will help you pass inspection.
We Build Robots and Careers
World's - #1 seeded in Archimedes, WON Archimedes and made it to Einstein
2016 NC District - Guilford County. #13 seeded, Finalist. Won Quality award.
IN District - Tippecanoe. #4 seeded. Won Innovation in Control award.
IN District - Perry Meridian. #3 seeded. Finalist. Won Excellence in Engineering award.
IN District - State Championship. #1 seeded. Finalist. Won Excellence inn Engineering award.
Unread 19-02-2008, 13:59
EricH's Avatar
New year, new team
FRC #1197 (Torbots)
Wayne, the example 10' long piece has to be counted as 10' for cost accounting unless the same stuff is available in 2' lengths. It's prorated on smallest available commercial quantity (that works...), not on how much you use. The example given in the rulebook is a 10" x 10" piece of material, cut from an 4' by ??' sheet, but available commercially in 1' by 1' sheets.
(Sorry, I'm not Al...)
Past teams:
Unread 19-02-2008, 14:00
Rookie Year: 1996
... If you buy a 10' long piece of steel but only use 2' than divide the 10' piece price by 5 to get the correct BOM price.
You do not need to include any small hardware (screws, bolts etc..) on the BOM. Don't sweat the small stuff, we will help you pass inspection.
Wayne, this is just about right.
Minor detail: when a team uses less material than they actually purchased, the cost of the part(s) made from that material can be shown on the BOM as the cost of the smallest commonly available quantity that they could have purchased.
Originally Posted by 2008 FRC Manual. 8.3.3.1, fifth major bullet
The cost of items purchased in bulk or large quantities may be prorated on the basis of the smallest commonly available unit that satisfies the need for the item.
o Example: A team purchases a 4' x 4' sheet of aluminum, but only uses a piece 10” x 10” on their ROBOT. The team identifies a source that sells aluminum sheet in 1’ x1’ pieces. The team may cost their part on the basis of a 1’ x 1’ piece, even though they cut the piece from a larger bulk purchase. They do not have to account for the entire 4’ x 4’ bulk purchase item.
You're also right about not having to count small fasteners; however, any fastener that costs more than $1 each must be included in the BOM.
Your final point is the main one: we the volunteers are there to help you pass inspection. We want every team to pass every inspection item so that they can compete.
(Sorry, I'm not Al either. I know he's around here somewhere ...)
Richard Wallace
since 2003
  #15   Spotlight this post!
Unread 19-02-2008, 14:22
Unsung FIRST Hero
Rookie Year: 1996
As far as looks go I fall somewhere between Rich and Wayne. Wayne is slightly taller and wears far more buttons than Rich or I do. Rich and I look alike but he has a St. Louis accent.
Karl,
The rules for how to account for parts are too expansive to include here. There are a number of examples included to help you judge what and how items should be included in your BOM. If you think of the reason behind the BOM and inspections, it is easier to see the thought process behind it. FIRST is trying to inspire by having you build a robot that must meet certain real or contrived constraints to help you think and to level the playing field for all teams. Gravity and playing field size are real world constraints, while robot size and weight and the parts cost limits are the contrived constraints. It is easier to say what you don't include, that being fasteners and items that you received in the KOP.
Oh by the way, buying a robot arm and splitting it into two separate assemblies for cost accounting doesn't fly and we will be watching for examples of that. Individual components must be below $400 each.
While we are on the subject of inspections. Safety of ball shooters will be very important during inspections. There will be concerns for the safety of not only participants, robots and field, but volunteers adjacent to the field as well. Designs that use great deals of stored energy, those that are designed to launch balls great heights or distances and those that have large moving parts (and the potential for breakage of those parts) will obviously be examined with those safety concerns in mind. Please read Team Update 5, we are.
Al
WB9UVJ
www.wildstang.org
New Bumper rule interpretation - straight from the lead inspector Gary Dillard Rules/Strategy 17 12-03-2007 14:56
Message from Chief Inspector Russ Beavis Rules/Strategy 0 29-01-2007 15:17
Inspector Training Posted Mark McLeod General Forum 3 02-03-2006 17:15
Sweet Repeat musings........................ skrussel Off-Season Events 3 19-10-2003 23:33
Notes from an Inspector - Save some grief and read! archiver 2001 1 23-06-2002 22:04
