2008 Gyro Code
Hi. I'm using Kevin's new 2008 code, but I can't figure out how to get the Gyro working in either autonomous mode or user mode. I believe that I set up the code right:
Code:
void Teleop_Init(void)
Initialize_Gyro();
if (Get_Gyro_Bias_Status() == GYRO_BIAS_NOT_DONE)
Start_Gyro_Bias_Calc();
while (t2 < 76)
printf("Calculating gyro bias. State: %d.\n\r", Get_Gyro_Bias_Status());
//Start_Gyro_Bias_Calc();
t2++;
Stop_Gyro_Bias_Calc();
printf("Gyro bias calculated: %ld.\n\r", Get_Gyro_Bias());
Code:
void Teleop(void)
Process_Gyro_Data();
tmpangle = Get_Gyro_Angle();
printf("Gyro Angle %d\n\r", tmpangle);
But unfortunately, the only output I get is "Gyro Angle 0". I'm sure I've got the gyro connected right, as I get values from Get_Analog_Value (and they change), but I don't get anything from Kevin's code. Can anyone help? |
Re: 2008 Gyro Code
FireJet,
The first thing you need to do is move the Process_Gyro_Data() into the Autonomous_Spin, Disabled_Spin and Teleop_Spin functions. This will allow a Gyro data to be processed all the time, not just during that 26.2 milliseconds loop. Remember, Get_Gyro_Angle returns a long value. You need to typecast it to an int for your printf statement. Something like this. Code:
tmpangle = int Get_Gyro_Angle();
Re: 2008 Gyro Code
Process_Gyro_Data() should be called in a spin function, as it needs to process the data after each interrupt and the telop function isn't fast enough.
Code:
while (t2 < 76)
t2++;
You should start the bias calc when t2=0, change your while loop to an if statement (so it gets called once each time through telop()) and stop it when t2=76 (or higher, since longer is better). You might also want to consider a delay so that the bias calc doesn't start right away, for everything to stabilize. Kevin has an example of all this in the ifi_frc_sensor project. |
Re: 2008 Gyro Code
I tried running Process_Gyro_Data in the _Spin functions, but it still won't help. To make sure that it wasn't my code that was broken, I also added a bit of debug output to Kevin's gyro.c code, in Process_Gyro_Data, so that it now looks like this:
Code:
void Process_Gyro_Data(void)
int temp_gyro_rate;
// fresh ADC data available?
if(Get_ADC_Result(GYRO_CHANNEL))
// should the completed sample set be used to calculate the gyro bias?
if(calc_gyro_bias == 1)
// put the ADC reading on the circular queue
Gyro_Queue[Gyro_Queue_Index] = Get_ADC_Result(GYRO_CHANNEL);
// increment the write pointer
Gyro_Queue_Index++;
// is the circular queue now full?
if(Gyro_Queue_Index == GYRO_QUEUE_SIZE-1)
// update the gyro bias status
Gyro_Bias_Status = GYRO_BIAS_BUFFER_FULL;
// If the index pointer overflowed, cut-off the high-order bit. Doing this
// every time is quicker than checking for overflow every time with an if()
// statement and only then occasionally setting it back to zero. For this
// to work, the queue size must be a power of 2 (e.g., 16,32,64,128).
Gyro_Queue_Index &= GYRO_QUEUE_INDEX_MASK;
else
// get the latest measured gyro rate
temp_gyro_rate = (int)Get_ADC_Result(GYRO_CHANNEL) - gyro_bias;
// update reported gyro rate and angle only if
// measured gyro rate lies outside the deadband
if(temp_gyro_rate < -GYRO_DEADBAND || temp_gyro_rate > GYRO_DEADBAND)
// update the gyro rate
gyro_rate = temp_gyro_rate;
// integrate the gyro rate to derive the heading
gyro_angle += (long)temp_gyro_rate;
else
gyro_rate = 0;
Reset_ADC_Result_Count();
else
printf("NO NEW ADC DATA.\n\r");
As well, I've tried replacing that hard-timed loop with this: Code:
while (Get_Gyro_Bias_Status() != GYRO_BIAS_BUFFER_FULL)
printf("Calculating gyro bias.\n\r");
Re: 2008 Gyro Code
*WPILIB/EasyC works around this by doing the communication in the background, but you have to deal with it in IFI and Kevin's code. |
Re: 2008 Gyro Code
I've read through the ADC and gyro readmes, and everything that they require should be set. I'm not sure about the timer, though... is there a readme for that?
As for the while loop, I did that because I wanted to run the gyro calculations in the initialization functions instead of the Teleop and Autonomous functions. |
Re: 2008 Gyro Code
-Kevin |
Re: 2008 Gyro Code
Looks like I need to get the really new 2008 code. I still have the version from January that has the old readme.txt file. I'll post more if it still doesn't work.
Re: 2008 Gyro Code
-Kevin Last edited by Kevin Watson : 09-02-2008 at 16:00. Reason: Spelling gaff |
#10
Re: 2008 Gyro Code
Just another question while I'm at it. I used the new default code to test the gyro, and in gyro.h I set "#define TENTHS_OF_A_DEGREE", but when I get input from the gyro I'm getting numbers that range from the double/triple digits to in the thousands, even when I divide by 10. Should this be happening?
#11
Re: 2008 Gyro Code
Re: 2008 Gyro Code
Even after it's been divided by 10? And even after that, I shouldn't be getting values over 6000, should I?
| Gyro code problem | AMIRAM | Programming | 10 | 23-01-2006 04:26 |
| problems using gyro/adc code with camera default code | tanstaafl | Programming | 7 | 22-01-2006 23:09 |
| gyro code | odin892 | Programming | 2 | 08-04-2003 14:50 |
| Gyro Chip Code | archiver | 2001 | 4 | 24-06-2002 00:57 |
