Go to Post And whether or not we are awarded in the course of the season, at its end our team will look back, and we’ll look at one another, and we will wonder how we were able to accomplish what we did. - John Wanninger [more]
Unread 09-02-2008, 11:07
eaglesfan10's Avatar
eaglesfan10 eaglesfan10 is offline
FRC #1647 (Iron Devils)
eaglesfan10 is an unknown quantity at this point
The Gyro in Disabled Mode
I was wondering about setting up the gyro in disabled mode. I realize that there is currently commented-out code in disabled.c to calculate the gyro bias. Am I also supposed to call Initialize_ADC() and Initialize_Gyro() in Disabled_Init? If I do, do I take those initialize adc and gyro functions out of teleop_init as well the start and stop gyro bias calc functions in teleop()? Any suggestions would really be appreciated. Thanks.
Unread 09-02-2008, 11:43
tseres's Avatar
tseres tseres is offline
obsessed with FIRST...
FRC #1565 (Think Tank Tech)
Team Role: Leadership
Rookie Year: 2007
tseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of light
Re: The Gyro in Disabled Mode
if you use kevin's new v3.0 sensor code, the gyro automatically starts to calculate the gyro bias in disabled mode. just read the readme
Unread 09-02-2008, 12:16
Kevin Watson's Avatar
Kevin Watson Kevin Watson is offline
La Cañada High School
FRC #2429
Kevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond repute
These functions should be called in teleop.c/Initialize().
-Kevin
Kevin Watson
Engineer at stealth-mode startup
http://kevin.org
Gyro Heading Correction in Operator Mode wkethman Programming 1 26-01-2008 15:25
Reading gyro before Autonomous mode Doug Leppard Programming 9 06-01-2008 21:02
How does disabled mode work? gnirts Programming 5 13-02-2006 11:47
competition_mode aka rxdata.rc_mode_byte.mode.disabled WizardOfAz Programming 3 29-02-2004 08:24
how can you use a gyro in autonomous mode magical hands Programming 3 02-01-2004 13:31
