Go to Post ...there's nothing worse than a problem you can't solve because you don't even know about it. - Dave Flowerday [more]
Unread 09-02-2008, 11:58
Shivang1923 Shivang1923 is offline
I make robot go VROOM VROOM!
FRC #1923 (MidKnight Inventors)
Shivang1923 has a spectacular aura aboutShivang1923 has a spectacular aura about
ROBOTC help
Hey. I'm having trouble programing a ROBOTC code into the RC. I keep getting this error:
Robot controller failed to respond
Possibly not powered on or corrupted firmware
Or low battery connection
or cable connections between controller and PC are wrong
Or incorrect port is selected on PC
Or FRC controller is not connected via tether or radio
-I checked every single one of these things and nothing fixes this error.
Heres the code I am using--
Code:
#include "FRC_Comp_Include.c"
void Initialization()
	bMotorReflected[port2] = true;
task Autonomous()
	motor[port1] = 30;
	motor[port2] = 30;
	wait1Msec(500);
	motor[port1] = 0;
	motor[port2] = 0;
task Human_Control()
		while(true)
		motor[port1] = frcRF[p1_y];
		motor[port2] = frcRF[p2_y];
the FRC_Comp_Include.c code is
Code:
void Initialization();
task Autonomous();
task Human_Control();
task main()
	bool bCurrentPhase;
	// Run the user initialization function
	Initialization();
	bCurrentPhase = !bIfiAutonomousPhase; // This will ensure that task will be started first time through
	// Loop forever checking to see if the phase has changed
	while (true)
		// Need to check whether the phase has switched. We only want to do action when a change has occurred.
		// This is because the "StartTask" function will either start a task running or restart an existing running task!
		if (bCurrentPhase != bIfiAutonomousPhase)
			// Need to switch phases
			//   1. Always stop the current task first
			//   2. Then start the new task.
			// If you start the "new" task before stopping the current task, then for a brief time you may have both tasks
			// running simultaneously.
			bCurrentPhase = bIfiAutonomousPhase;
			if (bCurrentPhase)
				StopTask(Human_Control);
				StartTask(Autonomous);
			else
				StopTask(Autonomous);
				StartTask(Human_Control);
		// Delay a little so this task minimizes it's CPU execution time. Otherwise it will take 50% of the CPU time and
		// slow down the "Autonomous" or "Human_Control" tasks which are doing the "real" time.
		wait1Msec(20);
Unread 09-02-2008, 13:10
Woody1458's Avatar
Woody1458 Woody1458 is offline
AKA: Woody Jansen
FRC #1458 (Danvillans)
Woody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to behold
Send a message via AIM to Woody1458
Re: ROBOTC help
Is the RC in program mode? hold down the program button.
"Everything we produce is made of: Duct Tape, zip ties, and hope" - Christian Allinson 1458
Anyone can watch Westcoast Choppers and see adults build things, but FIRST is great because it encourages kids to do the building and adults to do the watching.
GO DANVILLANS!!
Unread 09-02-2008, 13:11
psy_wombats's Avatar
psy_wombats psy_wombats is offline
AKA: A. King
FRC #0467 (Duct Tape Bandits)
Rookie Year: 2007
psy_wombats has a spectacular aura aboutpsy_wombats has a spectacular aura aboutpsy_wombats has a spectacular aura about
Re: ROBOTC help
I doubt that you have a coding problem, it seems that the downloading is the problem. Usually when I get this problem, I either have two IFI Loaders open or haven't compiled the code after cleaning it. Are either of those two the case? Otherwise, how did you test the items listed?
Unread 09-02-2008, 13:19
rpgcubed's Avatar
rpgcubed rpgcubed is offline
AKA: Nick
FRC #2456 (Recycle-It!)
rpgcubed is an unknown quantity at this point
Re: ROBOTC help
Whatever you do, do not press the program button. That deletes the ROBOTC Firmware and requires you to redownload it. If you do need to download it, it's under the Robot heading. Also you could try reconfiguring the COM port under View -> Preferences.
"The scientists of today think deeply instead of clearly. One must be sane to think clearly, but one can think deeply and be quite insane."
Nikola Tesla (1857 - 1943)
Free ROBOTC for all 2008 FIRST Robotics Teams! Brandon Martus Announcements 12 01-02-2008 11:22
Setting up an analog input in RobotC for IFI. NSolarz Programming 2 30-01-2008 20:23
ROBOTC - Controller ShawnHanna Programming 1 30-01-2008 20:20
Free ROBOTC for all 2008 FIRST Robotics Teams! timville Programming 0 09-01-2008 10:27
Congrats to the Robotc Knights! MattB703 Thanks and/or Congrats 0 18-03-2002 15:07
