Go to Post Stupid rules are not meant to be broken; they're meant to be changed. Unless and until they are changed, breaking them is wrong. - Alan Anderson [more]
Unread 09-02-2008, 16:25
dtengineering's Avatar
dtengineering dtengineering is offline
Teaching Teachers to Teach Tech
AKA: Jason Brett
no team (British Columbia FRC teams)
dtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond repute
1346 Far from Finished...
Here's a little updated video from Vancouver. Although we are far from finished and have some safety interlocks, a couple of bumpers, the "poker" that attches to the taller upright tube on the back of the robot to knock the trackball down, the entire hybrid/autonomous mode, a lot of practice and testing and a possible lifter/gripper mechanism left to go, we finally got the robot to drive and launch on Friday night.
It was actually kind of interesting Friday night as the school was hosting it's 50th Anniversary party that night and had about 3,000 alumni visiting. We were a "display" and people would drop by the shop, talk to the communications team members and watch the build team members do their thing. People who visited early in the night saw a disassmbled machine. Partway through the evening they saw a machine that needed the pneumatics hooked up and the code updated. If they came back towards the end of the evening they saw a big blue ball flying through the air and a robot rolling around the floor.
If you look up in the rafters towards the end of the video you'll see some of the things we do when we aren't building robots.
The specs are: about 80 pounds of robot so far (the first time ever that we haven't had to drop weight in the last week of build), with the launcher powered by four 1.5" x 8" cylinders with a 2" pre-load and two clippard tanks at 60psi downstream of the valve. It takes about 17 seconds after the shot for a complete recharge of the pneumatic system. There are two 6" IFI traction wheels on the front powered by two CIMs on the KOP gearbox driving a 32:22 sprocket set for speeds over 10fps, and two 6" AM Omnis unpowered on the back. Rotational stability is provided by a gyro.
See you in Portland and Seattle!
Jason
1346 Trackball Launcher dtengineering Robot Showcase 5 01-02-2008 11:32
pic: 1346 underglow 1 dtengineering Extra Discussion 3 01-05-2007 22:24
pic: 1346 Robot 2007 dtengineering Extra Discussion 3 05-03-2007 00:39
1346 mecanum b_mallerd Robot Showcase 4 30-01-2007 02:00
pic: 1346 - Wood is Good dtengineering Robot Showcase 21 14-02-2006 02:15
