wiring a keyang
I tried searching, but im having trouble figuring out how to wire the keyang thats connector is not provided in the kit
do u guys just soder on a connection? thanks for the help |
Re: wiring a keyang
In the bag with all the crimp fasteners, there should be 4 silver connectors. these and the two small black plastic housings get put together to form a connector, which wires can then be connected to.
(look on the bottom of page 12 of the KOP checklist to see what I'm talking about) |
Re: wiring a keyang
Look on page 12 of the KOP document. They are supplied to you there.
http://www.usfirst.org/uploadedFiles...klist-RevB.pdf |
Re: wiring a keyang
alright thanks a bunch! can I also use those on a nippo-denso motor?
Re: wiring a keyang
I haven't ever used the Denso motor, but I imagine it would work.
Edit: according to the tips, guidelines, and good practices section of the manual, you can order a matching part, but small slide-on crimp connectors will work as well. Last edited by Joe G. : 09-02-2008 at 18:17. |
Re: wiring a keyang
does anyone know where to get replacements. Need them very badly.
Re: wiring a keyang
I think these might work:
http://www.ifirobotics.com/accessories.shtml 2-Pin Battery Connector Pack - Mates to the Mini RC not 100% sure though |
| Keyang Motors | R.C. | Motors | 1 | 13-02-2008 20:23 |
| Keyang Motor? | RoboGeek99 | General Forum | 2 | 18-01-2008 15:58 |
| Wiring the Keyang Motors | aaeamdar | Electrical | 3 | 15-02-2007 07:49 |
| keyang motor | wedellm | Motors | 2 | 14-02-2007 02:37 |
| Keyang motors | zarb | OCCRA | 1 | 22-09-2003 01:44 |
