Alright this is Sparky's electrical board:
![]() ![]() Hope we didn't make any team jealous!!! Great Job by Mr. Jeff, Tri and me!!! *the PWM's are still to be cut to custom size and put on ![]() Last edited by sayso_411 : 09-02-2008 at 22:43. |
Re: Team 384's Electrical Board!!!
7 victors and 4 spikes!!!! what are you powering with all of that?
Very nice!
Check the wiring for the top two Victors in the second photo. It looks like the positive and negative connections are reversed. |
Thats one clean electrical bored. Where did you get the nifty right angle crimp connectors?
7 Victors and 4 spikes isn't that bad. We have 7 Victors and 2 Spikes, and I imagine Sparky is probably just using a couple more cylinders than us. We've gone up to eight victors before, and I've seen as many as twelve used.
I'm jealous. My team doesn't design around a set electronics board beforehand, we just get whatever random space is left and have to work with it
Keep guessing you will see at the nationals ![]() Yea we had the chasis and we designed around that dimensions |
There are also no wires running to the MAXI (gold colored) fuse panel for the CIMs.
#10
All Grounds from the Victors need to run directly to the Distribution Block.
#11
required to be run directly to the distribution block, but wiring all 40 amp ground returns to the distribution block, as shown in the provided wiring diagram, is a really good idea. I have seen a lot of fried pushons and these were operating at currents much lower than the CIM motor draws. Eugene |
#12
Thanks for the clarification. Thats what I meant.
| The Electrical Board for Team 2177 | Rachel2177 | General Forum | 13 | 26-01-2008 22:38 |
| TEam #2531's Robot-- Chassis and Electrical Board is done!! | beemgruem | General Forum | 17 | 24-01-2008 21:26 |
| Name our Electrical Board! | Excelsior | Chit-Chat | 17 | 19-01-2006 11:14 |
| Team 384's Animation Submission | Joe Matt | 3D Animation and Competition | 11 | 27-02-2004 20:02 |
| team 384's aniimation | Funkymunkey90 | 3D Animation and Competition | 7 | 20-03-2002 19:13 |
