Go to Post To paraphrase a common answer from the GDC: There is no rule that explicitly forbids this. - MechEng83 [more]
Unread 02-10-2008, 01:21 AM
BillfromBTW's Avatar
BillfromBTW BillfromBTW is offline
FRC #1209
BillfromBTW is an unknown quantity at this point
pic: BTW-1209 hurdling robot
Unread 02-10-2008, 02:55 AM
jason701802's Avatar
jason701802 jason701802 is offline
FRC #0753 (The High Desert Droids)
jason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant future
Re: pic: BTW-1209 hurdling robot
two questions, is that an entirely pvc frame? and what makes the lift go up?
Jason
Unread 02-10-2008, 03:05 AM
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
I'm going to guess 8020. PVC as second guess (though why PVC in a drivetrain application, I don't know).
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 02-10-2008, 10:16 AM
flamefixed flamefixed is offline
FRC #0219 (Team Impact)
Team Role: Mechanical
flamefixed is on a distinguished road
looks like 8020. i see the special connectors and accessories
Unread 02-10-2008, 11:49 AM
llama llama is offline
AKA: Michael Goelz
FRC #2077 (Kettle Moraine Robotics/Laser Robotics)
llama is an unknown quantity at this point
Send a message via AIM to llama
we are using 2020 (8020 is the brand name) as well and i believe i saw the video you had of your lift on you tube and it is essentially the same as ours but we are using two pillars of 2020 with a section in the center for our claw
yours looks like its WAY lighter than ours (we have about 7lb right now to finish making edits and then we will have to start swiss cheesing) but also looks a little structurally unsound...
Unread 02-10-2008, 01:12 PM
sdcantrell56's Avatar
sdcantrell56 sdcantrell56 is offline
AKA: Sean
FRC #2415 (Wired Cats)
sdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond repute
You should probably set your lift so that there is more overlap between sections. This will increase the strength dramatically as well as reduce friction.
Mentor 2415
pic: hurdling falconmaster Extra Discussion 7 02-04-2008 08:23 AM
Hurdling SSMike Rules/Strategy 3 01-19-2008 01:21 PM
hurdling daftpunk79 General Forum 5 01-08-2008 08:06 PM
Hurdling akash155 Rules/Strategy 3 01-05-2008 11:50 PM
summer coming... need job!!! btw, who's coming to Berkeley? archiver 2001 0 06-24-2002 03:46 AM
