Go to Post There will always be a point in your FIRST experience when you realize you can get away with something that is against the rules. It is at that point when you have a choice to make about your own personal ethics, and what sort of example you will set for your students. - ToddF [more]
Unread 10-02-2008, 03:52
Japper's Avatar
Japper Japper is offline
FRC #3692 (RocknRobots)
Rookie Year: 2007
Japper has a spectacular aura aboutJapper has a spectacular aura about
starting/ending robot configuration
Once a match is over, I am under the assumption that all robots are disabled per their connection to the field via the competition port on the OI.
Last year, we found our robot to be left in several different positions (based on its last action before being disabled) other than the compact starting position making it difficult (at times) to gather up the robot and cart it off the field and back to the pit.
Is there a way to have a button connected to the RC or some sort of a way to set the robot to its starting configuration without having an OI tethered or without radio control from the OI?
Thanks
Unread 10-02-2008, 05:05
adamm adamm is offline
AKA: Michael Adam
FRC #1671 (The Bird Brains)
adamm is just really niceadamm is just really niceadamm is just really niceadamm is just really niceadamm is just really nice
Re: starting/ending robot configuration
Well, in order for the RC to activate your User Code, AN OI MUST BE ATTACHED TO THE RC. The only way to be able to control the robot to move back to its home position would be to connect an OI.
You could solve this by installing a button on your robot via a digital input, then just connecting a spare OI with a tether Cable. (The robot shouldn't move, but it depends on how you have the robot programmed.) Now, in your code, have the robot return to is 'home' position ONLY when the button is pressed. If that button is placed properly, it shouldn't activate during a match.
You could store the OI and tether on your cart and when you are done with the match, grab the two things, run out to the robot, plug it in, and press the button.
This is all theoretical, but it should work.
Michael Adam
Director, Central Valley Robotics
FLL and FLL Jr. Affiliate Partner, Central California (2009-Present)
Member, Central Valley Regional Planning Committee (2012-Present)
Volunteer of the Year, Central Valley Regional (2015)
FRC Control System Advisor (2013-Present)
FRC Scorekeeper (2015-Present)
Mentor, Team 1671 (2009-Present)
Member, Team 1671 (2005-2009)
Unread 10-02-2008, 12:34
Sunshine's Avatar
Sunshine Sunshine is offline
Mr. S
FRC #2062 (C.O.R.E)
Rookie Year: 2007
Sunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to behold
The only rule that I see that addresses this:
Arena Reset - ROBOTS must be designed to permit the release and removal of any TRACKBALLS from the ROBOT without being powered up after a MATCH. If a ROBOT violates this rule, the offending TEAM will be warned and requested to modify the ROBOT. If the modification is not made, the ROBOT may not be permitted to compete in future MATCHES.
Last year as a rookie team we had to tether our robot at the completion of every match to get the lifts back up. We were questioned at the first regional but were told that if we could do it very quickly we would be okay. We practiced and ended up being fine at both the regional and national competition.
Would we do this again, no
But if all else fails and you can show that you are not holding up the next match, I believe you should be fine.
I would suggest that you ask your question on The Q&A forum and get the message from the experts.
C.O.R.E. Community Of Robotic Engineers
2015 Wisconsin Regional Champs, Safety Award
2015 Midwest Regional Champs, Safety Award, Industrial Controls Award
2014 Midwest Regional Judges Award
2013 Lake Superior Champs
2012 World Championship Safety Award, World Finalist for the Autodesk Award
2011 Wisconsin Regional - Website Award 10,000 Lakes - Innovation in Control, Safety Award
2010 World Championship - Archimedes Semi-Finalists -World Finalist for the Autodesk Award
2010 10,000 Lakes Regional Champs, Entrepreneurship Award; Wisconsin Regional- Entrepreneurship Award, Safety Award
2009 WI Regional- Quality Award, Safety Award 10,000 Lakes - Safety Award, Motorola Quality Award, Animation Award
2008 World Championship Safety Award
2008 Wisconsin Regional Champs, Safety Award
2008 St. Louis Regional Entrepreneurship Award, Safety Award, Website Award
2007 Wisconsin Regional All-Star Rookie Award
Unread 10-02-2008, 15:34
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
There is a way to put the robot back in starting configuration without powering it up. It's called making sure you don't need to be Superman to collapse it by hand. Failing that, try making the offending part(s) able to be easily removed, as 488 did last year.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 10-02-2008, 16:28
Mike Schreiber's Avatar
Mike Schreiber Mike Schreiber is offline
FRC #0067 (The HOT Team)
Mike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond repute
we had a similar problem with our ramps last year and the lift leg that we used. We had to lower the lift leg to be able to actually roll the robot. Our solution was to simply bungee cord everything together, pick it up, and walk off the field. After the match we tethered the robot and reset it. The only problem we encountered with this design was in the finals when they told us to leave our controls at the player station to save time and our driver didn't think about resetting the robot, although refs are perfectly understanding if you say we need the controls to reset.
I'm not sure if this is an option for you, but we thought it was the easiest solution.
Starting configuration at end of match? latonya Rules/Strategy 3 06-02-2008 15:59
pic: Team 1178 Robot - Starting Configuration Jake M Extra Discussion 1 01-03-2007 22:34
Robot Starting Position Alignment Makubesu Rules/Strategy 2 09-02-2006 19:16
Nerf ball starting at 12m/s 45 degree angle ending at 8ft 6in w/ air resistance Ethulin Technical Discussion 39 14-01-2006 19:04
Picture of robot starting zone? Jeff Rodriguez General Forum 2 06-01-2003 22:37
