Go to Post I'll guess those tie-dyed, numbered balls are used for alliance-partner lotto. :D - Richard Wallace [more]
Thread Tools Rating: Thread Rating: 4 votes, 5.00 average. Display Modes
Unread 10-02-2008, 04:31
DWB DWB is offline
FRC #1717
DWB is an unknown quantity at this point
Team 1717 Teaser
After 5 weeks of extensive CADing we are finally ready to start machining parts, take a look.
Unread 10-02-2008, 19:23
scottcook scottcook is offline
FRC #1717
scottcook is an unknown quantity at this point
Re: Team 1717 Teaser
We would have had it sooner, but our lead drafter cut off his pinky in a tragic ice skating accident, he says when he's drafting its like moving from medium to hard in guitar hero.
Unread 10-02-2008, 19:36
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
Wow!
I uh, don't know if i want to go ice skating anymore...
Is that really your robot design?
-q
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
Unread 10-02-2008, 21:09
DWB DWB is offline
FRC #1717
Yeah, Why? is it not legit?
Unread 10-02-2008, 21:47
AKA: Alex
In that case, excuse me for my assumed note of sarchasm.
What motors are you using to run your fan? What are you using for a fan?
-q
Unread 10-02-2008, 21:59
Éowyn Éowyn is offline
no team ((no team))
Éowyn is a splendid one to beholdÉowyn is a splendid one to beholdÉowyn is a splendid one to beholdÉowyn is a splendid one to beholdÉowyn is a splendid one to beholdÉowyn is a splendid one to beholdÉowyn is a splendid one to behold
Methinks Qbranch is having his leg pulled.
Unread 10-02-2008, 22:04
EricH's Avatar
Happy Birthday! EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
Even 1717 probably won't be able to pull a fan off. How many "Wind Walls" worked during '06? And those balls were smaller than this year's are...
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 10-02-2008, 22:07
Mike Schreiber's Avatar
Mike Schreiber Mike Schreiber is offline
FRC #0067 (The HOT Team)
Mike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond repute
don't doubt 1717's ability to be awesome...
If you do make a fan I want to see you at nationals
Unread 10-02-2008, 23:23
DWB DWB is offline
FRC #1717
Thanks man, you're the best
Unread 10-02-2008, 23:27
dtengineering's Avatar
dtengineering dtengineering is offline
Teaching Teachers to Teach Tech
AKA: Jason Brett
no team (British Columbia FRC teams)
dtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond repute
Something like this just might work... but you will have to modify your Victors to get enough power. Check out the radical modifications this team has tried.
From a big fan,
Jason
Unread 11-02-2008, 08:19
AKA: Alex
Actually... you don't have to... not if you use three CIMs to run it. When i did my calculations above, I used the output of three CIMs at 40A (at which point they output 250Wo).
Yeah, it's 120A total, but so what?
-q
Unread 10-02-2008, 22:54
AKA: Alex
Leg pulled or not, you've got my interest. Using this fan as a basis of calculation (since it fits inside the robot footprint), it actually could work.
A CIM motor puts out about 250Wo mechanical, comfortably. This fan standardly uses a 1hp=746Wo mechanical motor, so three CIM motors would run the fan at it's full 8,400cfm rate, or 10.5lb of air every second at around 40mph. This means you're providing a thrust of 85.164696N or 19.1457853 pounds force. AKA, THE BALL WILL HOVER.
Okay, now i'm too worn out to tell you how high, but I can tell you, it will hover above the fan.
I sooooooooo want you to do this!!!!!!!!!!!
-q
Unread 10-02-2008, 23:06
Dan Petrovic's Avatar
Dan Petrovic Dan Petrovic is offline
Got my degree and ready for more!
FRC #0166 (Chop Shop)
Dan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond repute
Oh yeah, MS Paint is my favorite CAD program, also.
Originally Posted by Koko Ed View Post
The sign applause was definately one of the best moments I had ever witnessed at a FIRST event.
Who knew silence could be so loud?
Mayhem in Merrimack hosts: 2005-2016 - Week Zero hosts in partnership with FIRST HQ: 2014-2016
Unread 11-02-2008, 22:30
CzarValvador's Avatar
CzarValvador CzarValvador is offline
AKA: Val
FRC #1717 (D'penguineers)
Team Role: Electrical
CzarValvador has a spectacular aura aboutCzarValvador has a spectacular aura about
You jest so lightly after such a crisis?
Not only do I have a deathly fear of ice skating now (and I've been playing Hockey Since I was a child!), but one of my best friends refuses to acknowledge the event because she was so terrified after witnessing that event. Now my friends and family second guess my judgment about safety (since the entire accident was my fault) on top of not being able to perform the simplest of tasks... Do you know what it feels like taking a shower in a plastic bag?
I no longer feel like a full human being, much less part of a community, especially one that treats the event with such misplaced humor.
Good luck finishing the final robot without me, find another CADer.
  #15   Spotlight this post!
Unread 11-02-2008, 22:39
Corey Oostveen's Avatar
Corey Oostveen Corey Oostveen is offline
FRC #2771 (Code Red Robotics)
Team Role: Coach
Corey Oostveen has a brilliant futureCorey Oostveen has a brilliant futureCorey Oostveen has a brilliant futureCorey Oostveen has a brilliant futureCorey Oostveen has a brilliant futureCorey Oostveen has a brilliant futureCorey Oostveen has a brilliant futureCorey Oostveen has a brilliant futureCorey Oostveen has a brilliant futureCorey Oostveen has a brilliant futureCorey Oostveen has a brilliant future
I am pretty sure they didn't use Microsoft paint...it just looks like a low resolution picture they took of the robot actually working. They want us all to think they haven't even started...but they don't have me fooled. Really good idea with back right wheel. The oval shape should provide a more stable ride over bumps.
Great design!
</sarcasm>
pic: Team 1717 Lift 2 rsilverstein Extra Discussion 8 19-04-2010 07:57
Team 1717 Lift Montage robotguru1717 Robot Showcase 18 20-04-2007 22:35
pic: Team 1717 Panel (alone) rsilverstein Extra Discussion 13 28-03-2007 16:06
pic: Team 1717 Lift 3 rsilverstein Extra Discussion 9 28-03-2007 15:38
pic: Team 1717 Panel rsilverstein Extra Discussion 3 27-03-2007 15:55
