ADXRS150 default voltage is too low..
Hello
Thanks for all your help with my previous post. Now I am having trouble with the sensor. In the manual, it says that the default voltage (at null) is 2.5V. but I am getting like 2.13V. It still behaves right. (it goes up or down as I rotate the sensor). Do you guys think it is bad sensor from factory? I know it wouldn't matter for using the sensor but I am kinda worried if there is a something wrong with sensor. The input voltage is exactly 5V. Thank you |
Re: ADXRS150 default voltage is too low..
Gyros don't always perfectly center where you might expect... odds are that your gyro is just fine. Common practice is to check the value of the gyro at startup (after everything has settled), and then use that as your neutral value.
| Set Default Digital inputs to Low? How? bad Analog value? | Generalx5 | Programming | 11 | 04-01-2007 18:57 |
| ADXRS150 gyro yaw rate sensor | Brian M. | Electrical | 13 | 17-10-2004 02:28 |
| ADXRS150/300 Sensor | m0rph3us | Electrical | 2 | 06-02-2004 22:37 |
| Bug: Login Problems - Session timeout value too low? | DanL | CD Forum Support | 4 | 09-01-2004 16:33 |
| Voltage Byte -> True Voltage | Ulibrium | Technical Discussion | 11 | 01-03-2002 08:55 |
