Go to Post Will the real John V-Neun please stand up, please stand up? - Elgin Clock [more]
Unread 10-02-2008, 14:40
Tottanka's Avatar
Tottanka Tottanka is offline
It isnt about bots,its about humans
AKA: Liron Gurvitz
FRC #3211 (The Y Team)
Tottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond repute
Main loop wierd problem
We hooked up our sensors, and use Kevin's ADC code to pull them.
Then we check for new adc data in the Process_Data_From_Local_IO() function in user rutines fast.
That is all fine and well (as in, it works exacly like it should).
We recently started to mess around with the autonomus mode, and our debug messages show us that sensor data isn't being updated while we set the autonomus button. when we unset it, the sensor data does gets updated.
We checked and Process_Data_From_Local_IO() isn't even called.
Code:
while (1)   /* This loop will repeat indefinitely. */
#ifdef _SIMULATOR
    statusflag.NEW_SPI_DATA = 1;
#endif
    if (statusflag.NEW_SPI_DATA)      /* 26.2ms loop area */
    {                                 /* I'm slow!  I only execute every 26.2ms because */
                                      /* that's how fast the Master uP gives me data. */
      Process_Data_From_Master_uP();  /* You edit this in user_routines.c */
      if (autonomous_mode)            /* DO NOT CHANGE! */
        User_Autonomous_Code();        /* You edit this in user_routines_fast.c */
    Process_Data_From_Local_IO();     /* You edit this in user_routines_fast.c */
                                      /* I'm fast!  I execute during every loop.*/
  } /* while (1) */
There is no aperent reason for the autonomus code and mode to affect the runing of the main loop, but for some reason it does.
HELP!!!
My FRC record: 10 Years,FTA (2008-9), 3 Teams(1947,2669,3211).3 RCA, 1 Championship EI(2016), 1 Divisional finalist (2016), 1 Regional winner.
Israeli 2016 Volunteer of the year.
Unread 10-02-2008, 14:44
Jon236's Avatar
Jon236 Jon236 is offline
AKA: Jon Mittelman
FRC #2648 (Infinite Loop)
Rookie Year: 2000
Jon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond repute
Re: Main loop wierd problem
Liron
Are you using Kevin's new code that uses the 3.0 C compiler? The ADC functions included in that build work well.
Jon
Jon Mittelman
Senior Judge Advisor New England & Israel 2014-2015
Infinite Loop Mentor 2011-2015
TechnoTicks Mentor 2000-2011
Championship Chairman's Award 2009 Team236 TechnoTicks
Judge 2010-2015 Championships
Senior Judge Advisor New England District Championship 2014-2015
Judge Advisor Tel Aviv Regional 2007-2015
Judge Advisor Pine Tree Regional 2013
Maine Regional Planning Committee
New England District Planning Committee
Lead Inspector Microsoft Tel Aviv Regional 2006-2008
Judge & Lead Inspector GM/Technion Tel Aviv Regional 2006
Judge UTC Hartford Regional 2006
Unread 10-02-2008, 14:46
Tottanka's Avatar
AKA: Liron Gurvitz
No, we are still using 2.6.
Unread 10-02-2008, 14:48
Jon236's Avatar
AKA: Jon Mittelman
Rookie Year: 2000
Try this code. ifi_frc_sensor.zip at http://www.kevin.org/frc/
from Kevin.org you can get the C compiler update and MPLab update (8.0) from microchip.com
Jon Mittelman
Unread 10-02-2008, 14:56
Tottanka's Avatar
AKA: Liron Gurvitz
the problem dosen't appear to be in kevin's code. it's the first thing we checked. the "cpu" dosn't seem to get to our sensor data pooling function for no aperent reason.
Unread 10-02-2008, 15:14
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Just add a call to Process_Data_From_Local_IO() in User_Autonomous_Code()
between the while and the if NEW_SPI_DATA check.
Wierd search behavior.... Salik Syed Programming 7 23-02-2006 13:12
Very wierd compiling problem! Max Brin Programming 6 08-02-2006 15:43
problem with using a loop CompMaster Programming 7 03-02-2006 16:44
Rewriting main loop Max Lobovsky Programming 4 04-01-2005 18:35
Wierd basic init Jeremy J Programming 5 06-02-2003 11:42
