Go to Post Of course this should be your decision- not the FIRST community's. Take charge of your destiny. - Wayne C. [more]
Go Back   Chief Delphi > Technical > Control System > Sensors
Unread 10-02-2008, 14:44
EEthan's Avatar
EEthan EEthan is offline
AKA: Ethan Zakai
FRC #0004 (ELEMENT)
EEthan is an unknown quantity at this point
Send a message via AIM to EEthan
Exclamation HALP I Need IR Board Firmware!
I used the IR Board that came with this year's KOP on our robot from last year to get some preliminary code working. I ran the board off of power from the RC's Digital IO bus and bypassed the regulator through R3. After about an hour of use the IR board completely stopped responding to any combination of stimuli despite correct Vdd levels across the board and a perfect physical state (no obvious parts missing).
I took the board home and plugged it into my PIC programer through that convenient little ICSP header they added to the board only to find that the PIC16LF87 on the board was so badly fried it wouldn't even handshake with the programmer. I'm guessing there was a surge on that bus that didn't kill the RC but that went above the PIC's 5.5v Absolute maximum.
I took the board back to school and soldered a through-hole DIP PIC16F88 (same part series, code should be portable in hex state) to the board where the fried uC used to be using point to point wiring and lots of super glue. I put a little program I wrote in ASM16 onto the chip to verify the LEDs, Reciever and button all worked, and then asked a team we mentor to bring in their board so I could pull the code off of their PIC and download it onto our ghetto-rigged board.
I got their IR board, plugged in my programmer, and OH NO the stock chips are code-protected! Our team is swamped and I don't have the time to write a program for this board in ASM16.
Does anybody have a copy of that firmware I can load onto our board?
I can't begin to explain how much that would help our team... from the time we spent mounting & coding encoders and a gyro on our new bot to the damage done to my ego from spending a full day fixing this board (lol)
Team 4
Head of Electronics & Programming 3 years running
future Electrical Engineer
and believer in the Pandimensional Twinkie theory
Unread 10-02-2008, 15:09
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Re: HALP I Need IR Board Firmware!
You can contact the designer of the board, Bob Grieb, at rlgrieb@verizon.net and see if he can help you.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Need an IR Board? Pavan Dave General Forum 1 10-02-2008 14:33
HALP! autonomous I am lose Shadow_Cat Programming 4 31-01-2008 21:37
Need tips on wiring the IR board Bryan Herbst Control System 4 12-01-2008 18:34
TTL CMUcam2 2004 eduRC bug... HALP PLZ ruddy Electrical 3 21-12-2007 22:26
RC Firmware JoeFryman Programming 1 12-02-2005 12:54
