main regulator
our main regulator shows zero psi...
the output arrow is leading to the festo>actuator. it looks like this.aerial view top left right bottom the right is the output arrow. leading to actuator the left is input from the cylinders the top is plugged the bottom has the presssure gauge. what is wrong here? |
Re: main regulator
Maybe you have the regulator dialed down to 0? Or the Gauge could be broken, I've seen broken gauges before too.
Re: main regulator
The pressure regulator needs to be "dialled in" to the correct pressure.
The top of the regulator forms the cap, which needs to be lifted in order to turn (kind of like a child-proof bottle) then when you push it back down it locks in place. Jason |
| Nason Pressure Regulator | Calvin_1631 | Pneumatics | 9 | 09-02-2006 00:40 |
| the best power regulator | John Gutmann | Electrical | 37 | 04-08-2005 08:52 |
| Voltage Regulator | Robby | Electrical | 5 | 18-01-2005 07:50 |
| 12v regulator | coreyjon | Electrical | 1 | 09-06-2004 22:08 |
| pressure regulator | blindguyinanorg | Pneumatics | 12 | 20-02-2004 08:54 |
