Maxbotix Ultrasonic Sensor Help...
Hey guys,
We have been experimenting with Maxbotix ultrasonic sensors and are a little disappointed by the output we are getting. We are trying to use the analog voltage output and (as verified by a voltmeter) the signal voltage will hold constant for a given distance and proceed to drop some and slowly walk back up to the stable voltage. This issue becomes more apparent at longer distances, to the point that the sensor readings are very rarely reliable. We are sequencing the sensors using an interface board to avoid interference and as near as we can tell the setup is fine. Has anyone else experienced this type of behavior? Any suggestions? |
| Parallax and Maxbotix ultrasonic sensors | Lucretius | Programming | 5 | 02-20-2008 02:34 PM |
| ultrasonic sensor problems... | couldntthinkofa | Programming | 2 | 01-05-2008 12:29 PM |
| Maxbotix Sonar Sensor | DonRotolo | Electrical | 17 | 02-04-2007 12:27 PM |
| Ultrasonic will not work with another Ultrasonic plz help | Jackel148 | Programming | 10 | 05-10-2006 03:31 PM |
| Ultrasonic Sensor | winners | Programming | 3 | 01-02-2006 08:55 PM |
