Go to Post Or, to put it another way: It's a sport where you build your own athlete. - EricH [more]
Unread 11-02-2008, 08:56
windell747 windell747 is offline
FRC #2477
windell747 will become famous soon enoughwindell747 will become famous soon enough
potentiometer typo?
Hi, I've made some modifications to a steering wheel and pedal set by replacing the 10K pots with 100K pots. This was done according to the Operator Interface reference guide. On page 5, they show a wiring diagram for a typical 100K potentiometer. The way I've used pots in the past are as variable voltage dividers. By taking a look at the wiring diagram, the third pin is labeled to have no connection. If this is true, then the pot would act as a variable resistor instead of as a voltage divider. I was wondering if this is a typo, or if I should disconnect the ground lines of the pots in the steering wheel and pedal set.
Thanks,
Windell
#2477
Potentiometer fezkazi Electrical 3 24-01-2007 13:29
Word of Warning: Google Typo = Bad Clark Gilbert Chit-Chat 15 02-05-2005 11:38
coding a potentiometer incognito_NICK Programming 5 14-02-2005 15:56
Potentiometer Joshua May Technical Discussion 8 22-05-2004 19:51
Woodie Flowers Award typo! archiver 2001 2 24-06-2002 01:26
