Go to Post "Trying to teach a nerd to be sensitive to girls is like trying to teach a dog Jamacian, and expect it to talk back" - Hansen302 [more]
Unread 11-02-2008, 15:10
Brandon_L Brandon_L is offline
The color orange triggers me
AKA: Brandon Liatys
FRC #2180 (Zero Gravity)
Rookie Year: 2007
Brandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond repute
IR board wiring
Were a rookie team, so we can't figure out probably to most simplist quesstion ever....
For the IR board, where do the 4 pinouts go to? We assumed the digital in/out. If so, how? Do we buy connectors? Does it go in the red wire slot, black wire slot, ect?
We also assume that wach of the 4 pinouts connect to 4 diffrent digital in/outs.
Please help,
Brandon
Unread 11-02-2008, 15:14
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: IR board wiring
Red is +5v, black is ground, white is signal...so you probably want to connect each of the IR board outputs to the white wire connection of one digital input on the RC, and connect the IR board ground to a black wire.
This could be done by cutting the male end off of 4 PWM cables and splicing the wires on the ribbon cable from the IR board to the PWM cables that have the end that will plug into the RC.
Use solder to splice the wires, and heat shrink tubing to cover the splice.
Wiring IR board DarKCroNo Sensors 3 09-02-2008 10:20
Wiring the IR sensor board govvijay Programming 9 05-02-2008 19:41
Need tips on wiring the IR board Bryan Herbst Control System 4 12-01-2008 18:34
pic: Team 668 Wiring Board burkechrs1 Extra Discussion 4 06-02-2007 01:56
Perf Board = BS2-IC Carrier Board? indieFan Electrical 2 16-09-2004 08:28
