Go to Post A robot with hands would be cool! - Koko Ed [more]
Unread 11-02-2008, 15:17
arhajder's Avatar
arhajder arhajder is offline
Arkadiusz Hajder
FRC #0640 (Viro)
Team Role: Leadership
arhajder will become famous soon enougharhajder will become famous soon enough
Send a message via AIM to arhajder
Exclamation Programming a third port
Hello my team wants to program the third port.What we did was change everything that said port1 or port2 and put in port3. we got a failled build that said
SPBRG3 AND TXSTA3bits is not defined.
How can we fix this problem?all are welcome(KEVIN!lol)
Unread 11-02-2008, 15:39
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: Programming a third port
What third port?
(There are only two serial ports available: the program port and the TTL port.)
Unread 11-02-2008, 16:10
arhajder's Avatar
Arkadiusz Hajder
FRC #0640 (Viro)
if u look on the IO there are four ports. we configuered our controller so that when we press a switch it activates a motor. we want to program that port so we can use it.
Unread 11-02-2008, 16:38
Software Architect
Again I ask, "what third port?" What are you looking at that shows four of them? Again I tell you that there are only two serial ports available.
Now I ask why a serial port has anything to do with using a switch to control a motor.
A motor usually connects to a Victor speed controller, which sets its output based on signals from one of sixteen pwm outputs on the Robot Controller. Some motors can be connected instead to a Spike relay module, which sets its output based on signals from one of eight relay outputs on the Robot Controller. Switches are typically connected directly to one of eighteen digital inputs on the Robot Controller.
Unread 11-02-2008, 16:52
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Maybe he means joystick ports.
Unread 11-02-2008, 19:40
arhajder's Avatar
Arkadiusz Hajder
FRC #0640 (Viro)
yes the joystick ports! We are using two joysticks that are connected into port 1 and port 2 on the operator interface. Then there are two extra ports(3 and 4). We created a controller that uses the third port. How would you program the third port!
Unread 11-02-2008, 19:42
psy_wombats's Avatar
psy_wombats psy_wombats is offline
AKA: A. King
FRC #0467 (Duct Tape Bandits)
Rookie Year: 2007
psy_wombats has a spectacular aura aboutpsy_wombats has a spectacular aura aboutpsy_wombats has a spectacular aura about
The third port should be exactly the same as the others. Simply replace the p1 or p2 prefix with p3. There shouldn't be any other changes.
tdlrali tdlrali is offline
FRC #0469 (Las Guerrillas)
tdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud of
the "aliases" for the third stick are p3_x, p3_y, and so on
Unread 11-02-2008, 19:47
arhajder's Avatar
Arkadiusz Hajder
FRC #0640 (Viro)
which source or header file would i input my data. I cant seem to find it anywhere
Unread 11-02-2008, 19:48
AKA: A. King
Rookie Year: 2007
All of the aliases are defined in the same header as the first two ports, that is, ifi_frc.h.
Unread 11-02-2008, 19:51
arhajder's Avatar
Arkadiusz Hajder
FRC #0640 (Viro)
but where would i write
ex.if(p3_sw_trig)
pwm03=254;
else
pwm01=127
Unread 11-02-2008, 19:54
AKA: A. King
Rookie Year: 2007
That should be in user_routines.c, like the other code.
Serial Port Programming phrontist General Forum 1 07-02-2004 16:13
Programming Port I/O MikeDubreuil Programming 4 10-02-2003 17:07
Programming Port Steven Carmain Programming 18 23-01-2003 21:36
Programming port input? Rickertsen2 Rumor Mill 1 21-01-2003 17:26
Programming Port GreenDice Programming 12 10-01-2002 09:14
