Holonomic Programming???
We at the skunkworks have had a ball trying to program the holonomic drive to work. If anyone has a mini-guide to programming such a system that would be woderful! Any help with this is appreciated. Speed controls, Gyros, accelerometers, with all this what should we do (getting the robot to go straight seems to be the biggest issue)
??? I'm not big into the programming part of our team but I feel the need to get the word out. I believe we use easy c or c. (we have a tank layout that we will end up using in our fist regional but we would all like to get holonomic running) Thanks a bunch!! Last edited by sknkmeistermatt : 11-02-2008 at 21:16. |
Re: Holonomic Programming???
This whitepaper has been invaluable to us:
http://www.chiefdelphi.com/media/papers/1836 You will likely want either a gyro or wheel encoders to close the loop on your drivetrain, or else getting it to go straight will be insanely difficult. |
thanks for the info!!!
| Holonomic vs Mecanum Help!! | kSniper | Technical Discussion | 10 | 25-03-2008 16:57 |
| Holonomic/Omni vs Defense | Alex Burman | Technical Discussion | 15 | 15-02-2006 20:35 |
| Holonomic Drive Question | Jeff Waegelin | Technical Discussion | 12 | 20-11-2005 21:23 |
| Holonomic... | Greg Perkins | Technical Discussion | 2 | 02-02-2005 11:59 |
| holonomic drives | Max Lobovsky | Technical Discussion | 5 | 10-03-2004 21:31 |
