Go to Post Let this be a hint to the hardware teams. Deliver that robot early and give the software and driving team time with the robot. IR3 has proven it can be done. - Doug Leppard [more]
Unread 11-02-2008, 21:16
greatman05 greatman05 is offline
AKA: Chavez Clemons Jr.
FRC #2224 (Phoenix Phenoms)
greatman05 is an unknown quantity at this point
Send a message via AIM to greatman05 Send a message via MSN to greatman05 Send a message via Yahoo to greatman05
Compiling Robot code...
Hello. Can the robot's code be compiled, and then the resulting complied file be transferred to a system with a serial port to then be transferred to the RC?
Unread 11-02-2008, 21:30
JBotAlan's Avatar
JBotAlan JBotAlan is offline
Forever chasing the 'bot around
AKA: Jacob Rau
FRC #5263
JBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond repute
Send a message via AIM to JBotAlan Send a message via Yahoo to JBotAlan
Re: Compiling Robot code...
Sure. Are you using easyC or MPLAB? When you compile with either, the compiler creates a .HEX file--you may need to change your Windows settings to see the extension--that can be transfered to a flash drive onto another pc; run IFI loader on that PC and use it to transfer the code onto the robot.
Why not install the compiler on the PC with the serial port? thumbdriving it over seems like a massive pain...
Or buy a USB to Serial converter. They can be had for less than $50 if you know where to look; most of the newer ones don't cause problems like the older ones did.
JBot
Aren't signatures a bit outdated?
Unread 11-02-2008, 21:37
Thanks for your reply...unortunately, not only is it late in the build to get a USB to Serial converter (6th week - CRUNCH time), but we also don't have a MPLab license to go on the other computer...Again, thanks for the info.
Unread 11-02-2008, 21:46
itsnotabigtruck itsnotabigtruck is offline
FRC #2002 (TETRA)
Rookie Year: 2007
itsnotabigtruck is on a distinguished road
You can install MPLAB/C18 on as many computers as you want.
Unread 11-02-2008, 21:47
JBotAlan's Avatar
AKA: Jacob Rau
FRC #5263
Just don't abuse this. I don't know what the letter of the license says, but respect the spirit of the license. Don't install it for a whole computer lab or anything like that... Things like that cause companies to do what intelitek did--lock down the licensing scheme so far that it is downright a pain to use.
Unread 11-02-2008, 21:50
Alexa Stott's Avatar
Alexa Stott Alexa Stott is offline
All I do is twin.
AKA: elixir
FRC #0025 (Raider Robotix)
Alexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond repute
Send a message via AIM to Alexa Stott
Getting hold of a USB to serial converter doesn't take much time--it's just a quick run out to Radio Shack and you're set.
|Email:alexastott[at]gmail.com|Facebook|@zelixir|Google+|
[University of Maryland Computer Science, Psychology]
[Brunswick Eruption]
Errors compiling Kevin's new code (pragmas) Bryan Herbst Programming 11 31-01-2008 12:50
Robot Timing Code robotrobot2 Programming 8 19-01-2008 14:18
Problem compiling Kevin Watson's code Spencer E. Programming 2 07-01-2008 00:34
Error in Compiling the Camera Code (B&W Version) VetteSlick Programming 7 20-01-2006 20:50
Default Robot Code lvhsrobotics Programming 2 10-01-2003 16:55
