Go to Post DonRotolo used COMMON SENSE. ... ... FIRST/Chief Delphi Community fainted! - PayneTrain [more]
Unread 11-02-2008, 23:46
Cullen Team 372 Cullen Team 372 is offline
FRC #0372
Cullen Team 372 is an unknown quantity at this point
Hooking up a custom OI panel
We are planning a panel of switches for our pneumatics, but might have a problem. I found the pinout guide at http://www.chiefdelphi.com/media/photos/26381 and it looks like there are only 4 digital outputs; we are needing eight. We could hook up a second serial connector, but I was wondering if the analog outputs could be used. I'll admit I am mostly a programming guy, so this may be an incredibly stupid question.
I know the analog outputs have a range of 0-255. If we hooked up our on off switch to them, would they return 0 or 255, depending on the switch position, or would they fry our OI?
I'm hoping I can be lazy without killing anything.
Unread 12-02-2008, 00:18
Racer26 Racer26 is offline
Racer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond repute
Re: Hooking up a custom OI panel
If you look at the IFI OI guide on www.ifirobotics.com, they show the full pinouts of those ports.
There are on ports 3 and 4 I believe, passthroughs of the 4 buttons on port 1/2. Thusly if you werent using the buttons on your p1 and p2 joys, you could use the passthroughs. I would just be a little worried about accidentally activating them from p1 (ie. driver accidentally clicks the trigger on the drive joy) Though that is easily remedied through a simple "modification" to the joy.
Unread 12-02-2008, 00:32
octothorpe's Avatar
octothorpe octothorpe is offline
AKA: Nick Felt
FRC #0766 (MA Bears)
octothorpe is a splendid one to beholdoctothorpe is a splendid one to beholdoctothorpe is a splendid one to beholdoctothorpe is a splendid one to beholdoctothorpe is a splendid one to beholdoctothorpe is a splendid one to beholdoctothorpe is a splendid one to behold
Disclaimer: I have wired a custom OI panel before, but I am not an electronics expert.
I'm pretty sure you mean analog versus digital inputs if you're talking about the OI. As for using the analog inputs with on-off switches, there shouldn't be anything wrong with that, certainly not on the OI-frying level. If you hooked a potentiometer up to that same analog input, you'd just be varying the voltage between ground and +5 anyway, so doing it with a toggle switch is no different. I think it makes sense and would allow you to use only one cable.
The one caution I do have is that on the programming side, you should probably do input < 127 means 0, input >= 127 means 1, lest fluctuations in voltage cause the analog value to read a 1 or 2 instead of 0 (and likewise with the 255 end).
Unread 12-02-2008, 17:26
FRC #0372
Thank you for your responses. I figured it might be a little to weird to program, but thank you for confirming that it would work.
Hooking up a backup battery neoshaakti Control System 7 26-01-2008 22:09
hooking up potentiometers chippermonky Programming 1 05-02-2007 20:04
Hooking up 2 Servos kutty18 Programming 7 04-02-2005 09:26
Problems hooking up a joystick to edubot Salik Syed Programming 2 24-03-2004 23:56
hooking up sensors to controller? Oakridege_665 Technical Discussion 5 21-01-2002 14:55
