Go to Post Good engineering involves working with constraints, not complaining about them. - Norman J [more]
Unread 12-02-2008, 09:41
jonboy jonboy is offline
Engineer/Mentor
FRC #0885 (The Green Team)
jonboy is an unknown quantity at this point
OI Disable Switch function???
Question about the OI Disable Switches: I have used the OI Port #3 Aux1 & Aux2 and Port #4 trig, thumb, aux1 and aux2 with the OI Disable Switches in both states and did not notice any difference in operation in regard to the effects from the port #1 #2 joystick switches. What do these switches really do?
... jon
Unread 12-02-2008, 10:00
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: OI Disable Switch function???
The eight DISABLE switches cause the OI to ignore specific switch inputs on joystick ports 1 and 3. Those switch inputs are duplicated by other pins on joystick ports 2 and 4. See the OI Reference Guide for explicit details, specifically section 15. DISABLE dipswitch on page 17.
Switch Function Problems darkdwarven Programming 2 29-01-2008 03:16
Disable After Autonomous trollin1st Control System 7 13-02-2007 14:54
Competition port Enable/disable switch box mpm967 Technical Discussion 3 10-01-2007 12:51
Bypass Disable Switch jakep Control System 36 19-08-2006 12:46
Need Help Wiring Micro Switch/Limiting Switch Windward Electrical 2 07-02-2006 18:26
