Go to Post The events are not just a competition, but a celebration of 6 weeks of hard work. - ChristinaR [more]
Unread 12-02-2008, 10:31
1213 1213 is offline
None #1213
1213 is an unknown quantity at this point
Creating hex file help
Well actually we have two questions to ask.
First, we can't seem to make our robot work with both a gyro and default code. It can work with one or the other, but not together.
Secondly, we can't seem to make a hex file that will work.
This is the error we get when we try to build our the gyro code from kevin.org in MPLab:
Thread would not exit normally. Process would not exit normally. Could not read language tool output from pipe (5). A Language plug in occurred and was logged. Build Failed.
we are using MPLab v 8.0
Unread 12-02-2008, 12:37
Racer26 Racer26 is offline
Racer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond repute
Re: Creating hex file help
You should be using the MPLAB and C18 Compiler provided to you in your Kit of Parts. I believe this is MPLAB v7.2, if I'm not mistaken. You may also wish to read up on how the C language works, so you gain understanding of how to merge the two codes. Also, You may find that EasyCPRO, as provided to teams by intelitek, is better suited to your (seemingly inexperienced) programming team.
Unread 13-02-2008, 08:33
Shivang1923 Shivang1923 is offline
I make robot go VROOM VROOM!
FRC #1923 (MidKnight Inventors)
Shivang1923 has a spectacular aura aboutShivang1923 has a spectacular aura about
v8.0 wont work... You HAVE to have 7.2 I made the mistake...took our team about a week to figure it out
MPLAB/c18 not creating a .hex file Cheezmeister Programming 7 15-02-2007 15:01
creating hex file seanl Programming 4 03-02-2007 22:08
"Error.MCP" file after HEX file trans iwdu15 Programming 1 24-01-2007 20:05
Hex file downloads Ryan M. Control System 2 29-10-2005 19:50
How do we convert a modified user routines file into a valid .HEX file HuskieRobotics Programming 13 28-02-2004 12:12
