Go to Post *gasp* Robotics? bad for your health? I refuse to accept that as an answer. - Kiwi_queen [more]
Unread 12-02-2008, 20:38
Alex.Norton's Avatar
Alex.Norton Alex.Norton is offline
Fidgetting
Alex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud of
Send a message via AIM to Alex.Norton Send a message via MSN to Alex.Norton
Vex Sensors to a loptop
I'm working on a project where we have a robot who's main processor is a laptop. We already have a motor controller and drive base but we want to hook up the vex sensors to the laptop because the system we are using is limited in its set of sensors.
Vex on the other hand is not. Basically we want to hook up a largish number of vex sensors to either the USB or serial inputs on the laptop. I was wondering if there is an adapter that is already made that would allow us to do this. We can design and build our own but we would rather not need to make the adapter itself. Writing a driver for an adapter isn't a problem, it is the adapter itself that we need.
Any help would be appreciated.
Alex Norton
Unread 12-02-2008, 21:15
Foster Foster is offline
Engineering Program Management
VRC #8081 (STEMRobotics)
Foster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond repute
Re: Vex Sensors to a loptop
You can write code on the Vex that sends sensor status down the primary serial port, use the orange cable to connect it to the laptop.
The serial link runs at 115K baud, so you should get a pretty good data stream down from the Vex sensor array. Two ways would be a continuous stream of all the values from all the sensors. With 8 digital inputs and 4 analog ports its a 20 character message.
Or you could just send the sensors that change value, so it would be less data transfer.
Unread 12-02-2008, 22:06
EHaskins EHaskins is offline
Needs to change his user title.
AKA: Eric Haskins
no team (CARD #6 (SCOE))
EHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond repute
Send a message via MSN to EHaskins
I've heard good things about the Phidgets I/O boards. They use a USB port, and they include APIs for C/C++, COM, Java, .NET, and Flash/Flex.
Eric Haskins KC9JVH
Unread 13-02-2008, 01:37
neutrino15's Avatar
neutrino15 neutrino15 is offline
plɹoʍ ollǝɥ
AKA: Jordan Perr
FRC #0694 (Stuypulse)
Rookie Year: 2007
neutrino15 is just really niceneutrino15 is just really niceneutrino15 is just really niceneutrino15 is just really nice
I don't think there is much difference between a dedicated IO board and a vex controller with code on it that does the same. If you already have a vex controller, do try using it.
Unread 14-02-2008, 16:34
Ziaholic's Avatar
Ziaholic Ziaholic is offline
Elec/SW Mentor
AKA: Marc
FRC #1164 (Project NEO)
Ziaholic is a jewel in the roughZiaholic is a jewel in the roughZiaholic is a jewel in the roughZiaholic is a jewel in the rough
New Laptop? Old one?
In the past, I've used LPT (parallel printer port) for a good, convenient, general purpose input/output ports.
Problem is, nowadays, it's hard to find a PC with an LPT port on it anymore.
There are 10 types of people. Those who understand binary, and those that do not.
Team #1164 - Project NEO Robotics
Extra "non-vex" sensors MRClark VEX 2 22-01-2008 16:46
Wheel Speed Sensors / Vehicle Speed Sensors chitu Technical Discussion 11 12-01-2008 02:46
Ultrasonic range sensors for Vex Robot OneCoolDude Programming 1 01-12-2007 09:22
[OCCRA]: VEX Sensors Silent_Stryker OCCRA Q&A 1 12-09-2006 16:30
where can we buy hall effect sensors or gear tooth sensors amirjpl Electrical 3 13-02-2006 11:02
